[elasticsearch-py] problem with connection
We're using elastic py from elastic 0.9 and we recently migrate to 5.2
We used to create a connection this way:
elasticsearch_server = ('127.0.0.1:9200') es = elasticsearch.Elasticsearch(elasticsearch_server, timeout=10, retry_on_timeout=True, sniff_on_start=False, sniff_on_connection_fail=True, sniff_timeout=10, serializer=JSONSerializerPython2(), sniffer_timeout=30)
Everything is working correctly until I add a new server that doesn't yet exist.
elasticsearch_server = ('127.0.0.1:9200') ---> elasticsearch_server = ('127.0.0.1:9200', '1.2.3.4:9200')
Then it raise a TransportError: TransportError(N/A, 'Unable to sniff hosts - no viable hosts found.')
If I remove the 1234 ip I can connect without problem.
What wrong? if I have 2 serves and I lost one, I can no more run with only one server???
This one was working perfectly with previous version so maybe because of new option?
I checked the doc but found nothing!
If somebody have a tip.
And another things: If I set sniff_on_start=True it raise a TransportError
I return debugging!
Here more information:
I put some debug in transport.py/sniff_hosts()
Here the list of the host sniffed which is correct (1234 Ip doesn't exist):
[{u'transport_address': u'127.0.0.1:9300', u'name': u'banana-node-1', u'roles': [u'master', u'data', u'ingest'], u'ip': u'127.0.0.1', u'host': u'127.0.0.1', u'version': u'5.2.2', u'build_hash': u'f9d9b74'}]
But after in the code he try to read the IP with the following key: "http_address"
And this key is not in the dict so it return a list of empty hosts??!!!! :cry:
Something wrong with my configuration need to set somewhere the transport protocol?
Dive back in the doc and debug.
========================= EDIT ======================
I figure out that the elasticsearch lib was not up to date :disappointed:
So I upgrade to the last version 5.2 (previously 5.0.1)
But my problem is still not solved, I set the timeout to 2 sec.
If the 2 servers are on, no problem, but If I switch off one, on each request I have a latency (~> timeout) and in my log this error:
ConnectTimeoutError: (<urllib3.connection.HTTPConnection object at 0x7f515c575390>, u'Connection to 172.16.40.151 timed out. (connect timeout=2)')
WARNING:elasticsearch:Connection <Urllib3HttpConnection: http://172.16.40.151:9200> has failed for 1 times in a row, putting on 60 second timeout.
