- install elastic search 1.4.2 (up and running http://hostip:9200 works)
- install kibana 3.1.2
- install lighthttpd.
1,2,3 are in the same node.
1,2,3 are run by same user/group.
Could anyone help?
configuration is below.
1-elastic-search-config. add line in elasticsearch.yml: http.cors.enabled:
true
2-kibana config: add one line in /var/www/kibana3/config.js: elasticsearch:
"http://localhost:9200",
3.-lighthttpd config: /etc/lighttpd/conf.d/kibana3.conf
<VirtualHost *:80>
#ServerName FQDN
DocumentRoot /var/www/kibana3
<Directory /var/www/kibana3>
Allow from all
Options -Multiviews
LogLevel debug
ErrorLog /var/log/lighthttpd/error_log
CustomLog /var/log/lighthttpd/access_log combined
Set global proxy timeouts
<Proxy http://127.0.0.1:9200>
ProxySet connectiontimeout=5 timeout=90
Proxy for _aliases and .*/_search
<LocationMatch
"^/(_nodes|_aliases|./_aliases|_search|./_search|_mapping|.*/_mapping)$">
ProxyPassMatch http://127.0.0.1:9200/$1
ProxyPassReverse http://127.0.0.1:9200/$1
Proxy for kibana-int/{dashboard,temp} stuff (if you don't want auth on
/, then you will want these to be protected)
<LocationMatch "^/(kibana-int/dashboard/|kibana-int/temp)(.*)$">
ProxyPassMatch http://127.0.0.1:9200/$1$2
ProxyPassReverse http://127.0.0.1:9200/$1$2
AuthType Basic
AuthBasicProvider file
AuthName "Restricted"
AuthUserFile /etc/lighthttpd/conf.d/kibana-htpasswd
Require valid-user
/etc/lighthttpd/lighthttpd.conf:
server.modules = (
"mod_access",
"mod_alias",
"mod_compress",
"mod_redirect",
"mod_rewrite",
server.document-root = "/var/www"
server.upload-dirs = ( "/var/cache/lighttpd/uploads" )
server.errorlog = "/var/log/lighttpd/error.log"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "myusernamerunelk"
server.groupname = "myusergrouprunelk"
index-file.names = ( "index.php", "index.html",
"index.htm", "default.htm",
" index.lighttpd.html" )
url.access-deny = ( "~", ".inc" )
static-file.exclude-extensions = ( ".php", ".pl", ".fcgi" )
Use ipv6 if available
#include_shell "/usr/share/lighttpd/use-ipv6.pl"
dir-listing.encoding = "utf-8"
server.dir-listing = "enable"
compress.cache-dir = "/var/cache/lighttpd/compress/"
compress.filetype = ( "application/x-javascript", "text/css",
"text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/ded075ac-5074-468d-88b1-8da76dffe842%40googlegroups.com.
