ELK index being deleted for a certain period without index lifecycle
Hi, I'm having an issue where certain index is being deleted after 28 days, I already removed the lifecycle policy which has 60 days delete phase and it is still being deleted after 28 days. Does anyone has experience on this? thanks
Which version of Elasticsearch are you using? Which index is being deleted? Do you by any chance have Curator running in addition to ILM?
Thank you for replying, we are using v7.16.2 on a Linux VM, this setup was done by another team so im still figuring out things, I checked elasticsearch VMs for any curator service and its not installed there. All indexes for different applications are 28 days, some don't have lifecycle policy by default but still only 28 days of logs remains.
Please share the index settings of the indices that should not be deleted after 28 days but still are. Please also share the configuration of any ILM policies that may be applying.
Here is the index settings :
  "settings": {
    "index": {
      "routing": {
        "allocation": {
          "include": {
            "_tier_preference": "data_cold,data_warm,data_hot"
          "require": {
            "_id": "yyHhORzXQ5SVHT578O0NKQ"
      "number_of_shards": "5",
      "provided_name": "my-index-2023.08.09",
      "creation_date": "1691539203997",
      "priority": "0",
      "number_of_replicas": "1",
      "uuid": "D_mJUU-zSBm07Dr22-idKg",
      "version": {
        "created": "7160299"
  "defaults": {
    "index": {
      "flush_after_merge": "512mb",
      "final_pipeline": "_none",
      "max_inner_result_window": "100",
      "unassigned": {
        "node_left": {
          "delayed_timeout": "1m"
      "max_terms_count": "65536",
      "rollup": {
        "source": {
          "name": "",
          "uuid": ""
      "lifecycle": {
        "name": "",
        "parse_origination_date": "false",
        "step": {
          "wait_time_threshold": "12h"
        "indexing_complete": "false",
        "rollover_alias": "",
        "origination_date": "-1"
      "routing_partition_size": "1",
      "force_memory_term_dictionary": "false",
      "max_docvalue_fields_search": "100",
      "merge": {
        "scheduler": {
          "max_thread_count": "2",
          "auto_throttle": "true",
          "max_merge_count": "7"
        "policy": {
          "floor_segment": "2mb",
          "max_merge_at_once_explicit": "30",
          "max_merge_at_once": "10",
          "max_merged_segment": "5gb",
          "expunge_deletes_allowed": "10.0",
          "segments_per_tier": "10.0",
          "deletes_pct_allowed": "33.0"
      "max_refresh_listeners": "1000",
      "max_regex_length": "1000",
      "load_fixed_bitset_filters_eagerly": "true",
      "number_of_routing_shards": "5",
      "write": {
        "wait_for_active_shards": "1"
      "verified_before_close": "false",
      "mapping": {
        "coerce": "false",
        "nested_fields": {
          "limit": "50"
        "depth": {
          "limit": "20"
        "field_name_length": {
          "limit": "9223372036854775807"
        "total_fields": {
          "limit": "1000"
        "nested_objects": {
          "limit": "10000"
        "ignore_malformed": "false",
        "dimension_fields": {
          "limit": "16"
      "source_only": "false",
      "soft_deletes": {
        "enabled": "true",
        "retention": {
          "operations": "0"
        "retention_lease": {
          "period": "12h"
      "max_script_fields": "32",
        "default_field": [
        "parse": {
          "allow_unmapped_fields": "true"
      "format": "0",
      "frozen": "false",
      "sort": {
        "missing": [],
        "mode": [],
        "field": [],
        "order": []
      "codec": "default",
      "max_rescore_window": "10000",
      "max_adjacency_matrix_filters": "100",
      "analyze": {
        "max_token_count": "10000"
      "gc_deletes": "60s",
      "top_metrics_max_size": "10",
      "optimize_auto_generated_id": "true",
      "max_ngram_diff": "1",
      "hidden": "false",
      "translog": {
        "generation_threshold_size": "64mb",
        "flush_threshold_size": "512mb",
        "sync_interval": "5s",
        "retention": {
          "size": "-1",
          "age": "-1"
        "durability": "REQUEST"
      "auto_expand_replicas": "false",
      "mapper": {
        "dynamic": "true"
      "recovery": {
        "type": ""
      "requests": {
        "cache": {
          "enable": "true"
      "data_path": "",
      "highlight": {
        "max_analyzed_offset": "1000000"
      "routing": {
        "rebalance": {
          "enable": "all"
        "allocation": {
          "include": {
            "_tier": ""
          "disk": {
            "watermark": {
              "ignore": "false"
          "exclude": {
            "_tier": ""
          "require": {
            "_tier": ""
          "enable": "all",
          "total_shards_per_node": "-1"
      "search": {
        "slowlog": {
          "level": "TRACE",
          "threshold": {
            "fetch": {
              "warn": "-1",
              "trace": "-1",
              "debug": "-1",
              "info": "-1"
              "warn": "-1",
              "trace": "-1",
              "debug": "-1",
              "info": "-1"
        "idle": {
          "after": "30s"
        "throttled": "false"
      "fielddata": {
        "cache": "node"
      "default_pipeline": "_none",
      "max_slices_per_scroll": "1024",
      "shard": {
        "check_on_startup": "false"
      "xpack": {
        "watcher": {
          "template": {
            "version": ""
        "version": "",
        "ccr": {
          "following_index": "false"
      "percolator": {
        "map_unmapped_fields_as_text": "false"
      "allocation": {
        "max_retries": "5",
        "existing_shards_allocator": "gateway_allocator"
      "refresh_interval": "1s",
      "indexing": {
        "slowlog": {
          "reformat": "true",
          "threshold": {
            "index": {
              "warn": "-1",
              "trace": "-1",
              "debug": "-1",
              "info": "-1"
          "source": "1000",
          "level": "TRACE"
      "compound_format": "0.1",
      "blocks": {
        "metadata": "false",
        "read": "false",
        "read_only_allow_delete": "false",
        "read_only": "false",
        "write": "false"
      "max_result_window": "10000",
      "store": {
        "stats_refresh_interval": "10s",
        "type": "",
        "fs": {
          "fs_lock": "native"
        "preload": [],
        "snapshot": {
          "snapshot_name": "",
          "index_uuid": "",
          "cache": {
            "prewarm": {
              "enabled": "true"
            "enabled": "true",
            "excluded_file_types": []
          "repository_uuid": "",
          "uncached_chunk_size": "-1b",
          "index_name": "",
          "partial": "false",
          "blob_cache": {
            "metadata_files": {
              "max_length": "64kb"
          "repository_name": "",
          "snapshot_uuid": ""
      "queries": {
        "cache": {
          "enabled": "true"
      "shard_limit": {
        "group": "normal"
      "warmer": {
        "enabled": "true"
      "max_shingle_diff": "3",
      "query_string": {
        "lenient": "false"
the ILM policy that I removed :
grep for for "delete" on elasticsearch logs
k8s-cluster.log:[2023-09-06T00:00:15,474][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.03] from [{"phase":"warm","action":"complete","name":"complete"}] to [{"phase":"delete","action":"delete","name":"wait-for-shard-history-leases"}] in policy [7-days-default]
k8s-cluster.log:[2023-09-06T00:09:19,331][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.03] from [{"phase":"delete","action":"delete","name":"wait-for-shard-history-leases"}] to [{"phase":"delete","action":"delete","name":"cleanup-snapshot"}] in policy [7-days-default]
k8s-cluster.log:[2023-09-06T00:09:19,785][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.03] from [{"phase":"delete","action":"delete","name":"cleanup-snapshot"}] to [{"phase":"delete","action":"delete","name":"delete"}] in policy [7-days-default]
k8s-cluster.log:[2023-09-06T00:09:19,900][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [events-metricbeat-2023.09.03/1MEQ9YqcSRm3fh8bUua6uQ] deleting index
k8s-cluster.log:[2023-09-06T01:00:00,006][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [.monitoring-es-7-2023.08.30/CL-MnfZBQcOrYXtxxP76JA] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,815][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index1-2023.08.09/eqVAEC8IQ9qMz7dfeTxujw] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,815][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index2-2023.08.09/yT-AJgYORiagQO7_fu6RGQ] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,815][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index3-2023.08.09/D_mJUU-zSBm07Dr22-idKg] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index4-2023.08.09/0Dorl8RaQiyY_lIsOGnxjg] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index5-2023.08.09/0DnFHE8ZRBumSXNxLZUzew] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index6-2023.08.09/Z4N7AEPkSZ6962tnMb79ug] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index7-2023.08.09/ym_66nYRQKGpgxAWfPqqVg] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index8-2023.08.09/PaxmbXpxRRGYYqpYSO8sUA] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index9-2023.08.09/UubobaEdTr6q92-R_RYkoA] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index10-2023.08.09/8oYrK9MYSu67uRwM1UT1YA] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index11-2023.08.09/pbFGzPJvR1CTXcK1Xjopfw] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index12-2023.08.09/7F66pVfBQbWfD7K5fiXZnA] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index13-2023.08.09/PdmK61_tSEWnGnPNuSdDfA] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index14-2023.08.09/439UYR1GRAKkOIIwUBQWAw] deleting index
k8s-cluster.log:[2023-09-06T01:00:55,816][INFO ][o.e.c.m.MetadataDeleteIndexService] [vm-ip-address] [index15-2023.08.09/PrK1e_XhRtiUbV7pNhHXAg] deleting index
k8s-cluster.log:[2023-09-06T01:25:00,009][INFO ][o.e.x.m.a.TransportDeleteExpiredDataAction] [vm-ip-address] Deleting expired data
k8s-cluster.log:[2023-09-06T01:25:00,024][INFO ][o.e.x.m.j.r.UnusedStatsRemover] [vm-ip-address] Successfully deleted [0] unused stats documents
k8s-cluster.log:[2023-09-06T01:25:00,025][INFO ][o.e.x.m.a.TransportDeleteExpiredDataAction] [vm-ip-address] Completed deletion of expired ML data
k8s-cluster.log:[2023-09-06T01:25:00,025][INFO ][o.e.x.m.MlDailyMaintenanceService] [vm-ip-address] Successfully completed [ML] maintenance task: triggerDeleteExpiredDataTask
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T00:00:15,474Z", "level": "INFO", "component": "o.e.x.i.IndexLifecycleTransition", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "moving index [events-metricbeat-2023.09.03] from [{\"phase\":\"warm\",\"action\":\"complete\",\"name\":\"complete\"}] to [{\"phase\":\"delete\",\"action\":\"delete\",\"name\":\"wait-for-shard-history-leases\"}] in policy [7-days-default]", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T00:09:19,331Z", "level": "INFO", "component": "o.e.x.i.IndexLifecycleTransition", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "moving index [events-metricbeat-2023.09.03] from [{\"phase\":\"delete\",\"action\":\"delete\",\"name\":\"wait-for-shard-history-leases\"}] to [{\"phase\":\"delete\",\"action\":\"delete\",\"name\":\"cleanup-snapshot\"}] in policy [7-days-default]", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T00:09:19,785Z", "level": "INFO", "component": "o.e.x.i.IndexLifecycleTransition", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "moving index [events-metricbeat-2023.09.03] from [{\"phase\":\"delete\",\"action\":\"delete\",\"name\":\"cleanup-snapshot\"}] to [{\"phase\":\"delete\",\"action\":\"delete\",\"name\":\"delete\"}] in policy [7-days-default]", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T00:09:19,900Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[events-metricbeat-2023.09.03/1MEQ9YqcSRm3fh8bUua6uQ] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:00,006Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[.monitoring-es-7-2023.08.30/CL-MnfZBQcOrYXtxxP76JA] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,815Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index1-2023.08.09/eqVAEC8IQ9qMz7dfeTxujw] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,815Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index2-2023.08.09/yT-AJgYORiagQO7_fu6RGQ] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,815Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index3-2023.08.09/D_mJUU-zSBm07Dr22-idKg] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index4-2023.08.09/0Dorl8RaQiyY_lIsOGnxjg] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index5-2023.08.09/0DnFHE8ZRBumSXNxLZUzew] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index6-2023.08.09/Z4N7AEPkSZ6962tnMb79ug] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index7-2023.08.09/ym_66nYRQKGpgxAWfPqqVg] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index8-2023.08.09/PaxmbXpxRRGYYqpYSO8sUA] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index9-2023.08.09/UubobaEdTr6q92-R_RYkoA] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index10-2023.08.09/8oYrK9MYSu67uRwM1UT1YA] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index11-2023.08.09/pbFGzPJvR1CTXcK1Xjopfw] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index12-2023.08.09/7F66pVfBQbWfD7K5fiXZnA] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index13-2023.08.09/PdmK61_tSEWnGnPNuSdDfA] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index14-2023.08.09/439UYR1GRAKkOIIwUBQWAw] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:00:55,816Z", "level": "INFO", "component": "o.e.c.m.MetadataDeleteIndexService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "[index15-2023.08.09/PrK1e_XhRtiUbV7pNhHXAg] deleting index", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:25:00,009Z", "level": "INFO", "component": "o.e.x.m.a.TransportDeleteExpiredDataAction", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "Deleting expired data", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:25:00,024Z", "level": "INFO", "component": "o.e.x.m.j.r.UnusedStatsRemover", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "Successfully deleted [0] unused stats documents", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:25:00,025Z", "level": "INFO", "component": "o.e.x.m.a.TransportDeleteExpiredDataAction", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "Completed deletion of expired ML data", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
k8s-cluster_server.json:{"type": "server", "timestamp": "2023-09-06T01:25:00,025Z", "level": "INFO", "component": "o.e.x.m.MlDailyMaintenanceService", "cluster.name": "k8s-cluster", "node.name": "vm-ip-address", "message": "Successfully completed [ML] maintenance task: triggerDeleteExpiredDataTask", "cluster.uuid": "Rd65RBeuTMuTzO9JLntixA", "node.id": "NNn-IhAJR1OUGe7DwhjtRQ" }
[2023-09-06T00:00:00,266][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [events-metricbeat-2023.09.06] creating index, cause [auto(bulk api)], templates [container-events-me
[2023-09-06T00:00:01,691][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [index12-2023.09.06] creating index, cause [auto(bulk api)], templates [], shards [1]/[1]
[2023-09-06T00:00:02,047][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [index14-2023.09.06] creating index, cause [auto(bulk api)], templates [index14
[2023-09-06T00:00:02,374][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [index7-2023.09.06] creating index, cause [auto(bulk api)], templates [], shards [1]/[1]
[2023-09-06T00:00:02,648][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [index3-2023.09.06] creating index, cause [auto(bulk api)], templates [aia_vitality_mpv_ve_vpf_template],
[2023-09-06T00:00:03,270][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [.monitoring-es-7-2023.09.06] creating index, cause [auto(bulk api)], templates [.monitoring-es], shards [1]/[0]
[2023-09-06T00:00:03,276][INFO ][o.e.c.r.a.AllocationService] [vm-ip-address] updating number_of_replicas to [1] for indices [.monitoring-es-7-2023.09.06]
[2023-09-06T00:00:03,833][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:03,977][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:04,024][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:04,063][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:04,142][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:04,194][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:04,268][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:04,311][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:04,354][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:04,465][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:04,503][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:04,562][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:05,049][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index7-2023.09.06/W4oGq-VoRnm4aEa913nGmA] create_mapping [_doc]
[2023-09-06T00:00:05,168][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:05,175][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index12-2023.09.06/Mp29r8kvSAidDmqF5HyzOA] create_mapping [_doc]
[2023-09-06T00:00:05,918][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:06,066][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:06,129][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:06,209][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:06,219][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index3-2023.09.06/VcD-YuWsR3OCSntBJ9nIHQ] update_mapping [_doc]
[2023-09-06T00:00:06,254][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:06,290][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:06,920][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:07,034][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:07,166][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:07,197][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:07,384][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:07,412][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:07,472][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:07,787][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:08,023][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:08,071][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:08,684][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:08,744][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:08,773][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:08,847][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:08,871][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:08,926][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:08,934][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index7-2023.09.06/W4oGq-VoRnm4aEa913nGmA] update_mapping [_doc]
[2023-09-06T00:00:08,956][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:09,430][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:09,529][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:09,563][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:09,648][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:09,723][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:10,056][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:10,102][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:10,166][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:10,270][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:10,616][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [index15-2023.09.06] creating index, cause [auto(bulk api)], templates [], shards [1]/[1]
[2023-09-06T00:00:11,255][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:11,304][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index9-2023.09.06/mJLPcC0ZQJKAV7ZbftI0Wg] update_mapping [_doc]
[2023-09-06T00:00:11,428][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index1-2023.09.06/r4fWU_4DRXmeDAGYNEFsxQ] update_mapping [_doc]
[2023-09-06T00:00:12,123][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:12,195][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:12,240][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index15-2023.09.06/78xZrurxRSusxq16AeNAig] create_mapping [_doc]
[2023-09-06T00:00:12,269][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [events-metricbeat-2023.09.06/0bgRxD-dRairRug9TsEyPA] update_mapping [_doc]
[2023-09-06T00:00:12,974][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:13,399][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [index11-2023.09.06] creating index, cause [auto(bulk api)], templates [], shards [1]/[1]
[2023-09-06T00:00:13,793][INFO ][o.e.c.m.MetadataCreateIndexService] [vm-ip-address] [index6-2023.09.06] creating index, cause [auto(bulk api)], templates [], shards [1]/[1]
[2023-09-06T00:00:14,147][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index11-2023.09.06/gXTi-IWBRSmUX86A3Bh-xg] create_mapping [_doc]
[2023-09-06T00:00:14,965][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:15,014][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index6-2023.09.06/zfQm8rC-RJCiBmQJPv7VKQ] create_mapping [_doc]
[2023-09-06T00:00:15,474][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.06] from [null] to [{"phase":"new","action":"complete","name":"comp
[2023-09-06T00:00:15,474][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.03] from [{"phase":"warm","action":"complete","name":"complete"}] ty-leases"}] in policy [7-days-default]
[2023-09-06T00:00:15,475][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"hot","action":"complete","name":"complete"}] to policy [7-days-default]
[2023-09-06T00:00:16,719][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:17,795][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.06] from [{"phase":"new","action":"complete","name":"complete"}] to7-days-default]
[2023-09-06T00:00:17,796][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"set_priority","name":"set_priorte-index"}] in policy [7-days-default]
[2023-09-06T00:00:17,986][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"readonly","name":"check-not-wri"}] in policy [7-days-default]
[2023-09-06T00:00:18,175][INFO ][o.e.c.m.MetadataIndexStateService] [vm-ip-address] adding block write to indices [[events-metricbeat-2023.09.05/ydTSg9vxQ7OcQ31lA2NYdg]]
[2023-09-06T00:00:18,396][INFO ][o.e.c.m.MetadataIndexStateService] [vm-ip-address] completed adding block write to indices [events-metricbeat-2023.09.05]
[2023-09-06T00:00:18,472][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"readonly","name":"readonly"}] ton"}] in policy [7-days-default]
[2023-09-06T00:00:18,569][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"migrate","name":"branch-check-s"}] in policy [7-days-default]
[2023-09-06T00:00:19,027][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"migrate","name":"migrate"}] to licy [7-days-default]
[2023-09-06T00:00:19,187][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"migrate","name":"check-migratioerge-check-prerequisites"}] in policy [7-days-default]
[2023-09-06T00:00:19,188][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"forcemerge","name":"branch-forcge","name":"check-not-write-index"}] in policy [7-days-default]
[2023-09-06T00:00:19,189][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"forcemerge","name":"check-not-wonly"}] in policy [7-days-default]
[2023-09-06T00:00:19,286][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"forcemerge","name":"readonly"}]policy [7-days-default]
[2023-09-06T00:00:20,032][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:21,378][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:44,616][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:00:46,470][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index12-2023.09.06/Mp29r8kvSAidDmqF5HyzOA] update_mapping [_doc]
[2023-09-06T00:02:59,491][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T00:09:19,331][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.03] from [{"phase":"delete","action":"delete","name":"wait-for-sharcleanup-snapshot"}] in policy [7-days-default]
[2023-09-06T00:09:19,785][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.03] from [{"phase":"delete","action":"delete","name":"cleanup-snapspolicy [7-days-default]
[2023-09-06T00:15:52,954][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"forcemerge","name":"forcemerge"] in policy [7-days-default]
[2023-09-06T00:19:19,330][INFO ][o.e.x.i.IndexLifecycleTransition] [vm-ip-address] moving index [events-metricbeat-2023.09.05] from [{"phase":"warm","action":"forcemerge","name":"segment-cou policy [7-days-default]
[2023-09-06T01:00:00,000][INFO ][o.e.x.m.e.l.LocalExporter] [vm-ip-address] cleaning up [1] old indices
[2023-09-06T01:00:08,415][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
[2023-09-06T01:00:16,189][INFO ][o.e.c.m.MetadataMappingService] [vm-ip-address] [index14-2023.09.06/qYaD5MTTQMKhpW7-WinZdA] update_mapping [_doc]
Go to the Kibana dev console and run GET _ilm/policy to see which policies exist in the cluster. Has the one you removed been deleted? Are there any other policies that could be applying to the indices you see being deleted?
thank you for your response! this is the output of the command :
  ".alerts-ilm-policy" : {
    "version" : 103,
    "modified_date" : "2023-08-23T10:17:34.008Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_primary_shard_size" : "50gb",
              "max_age" : "30d"
    "in_use_by" : {
      "indices" : [ ],
      "data_streams" : [ ],
      "composable_templates" : [ ]
  ".deprecation-indexing-ilm-policy" : {
    "version" : 1,
    "modified_date" : "2021-12-17T03:55:17.357Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_primary_shard_size" : "10gb",
              "max_age" : "14d"
    "in_use_by" : {
      "indices" : [
        ".ds-.logs-deprecation.elasticsearch-default-2022.09.09-000020",
        ".ds-.logs-deprecation.elasticsearch-default-2022.04.08-000009",
        ".ds-.logs-deprecation.elasticsearch-default-2022.05.20-000012",
        ".ds-.logs-deprecation.elasticsearch-default-2023.05.05-000037",
        ".ds-.logs-deprecation.elasticsearch-default-2022.10.21-000023",
        ".ds-.logs-deprecation.elasticsearch-default-2022.02.25-000006",
        ".ds-.logs-deprecation.elasticsearch-default-2023.03.24-000034",
        ".ds-.logs-deprecation.elasticsearch-default-2023.01.27-000030",
        ".ds-.logs-deprecation.elasticsearch-default-2022.07.01-000015",
        ".ds-.logs-deprecation.elasticsearch-default-2022.12.30-000028",
        ".ds-.logs-deprecation.elasticsearch-default-2023.08.11-000044",
        ".ds-.logs-deprecation.elasticsearch-default-2023.07.28-000043",
        ".ds-.logs-deprecation.elasticsearch-default-2022.10.07-000022",
        ".ds-.logs-deprecation.elasticsearch-default-2022.07.15-000016",
        ".ds-.logs-deprecation.elasticsearch-default-2023.03.10-000033",
        ".ds-.logs-deprecation.elasticsearch-default-2023.07.14-000042",
        ".ds-.logs-deprecation.elasticsearch-default-2022.11.18-000025",
        ".ds-.logs-deprecation.elasticsearch-default-2022.03.11-000007",
        ".ds-.logs-deprecation.elasticsearch-default-2022.06.17-000014",
        ".ds-.logs-deprecation.elasticsearch-default-2022.04.22-000010",
        ".ds-.logs-deprecation.elasticsearch-default-2022.06.03-000013",
        ".ds-.logs-deprecation.elasticsearch-default-2023.06.02-000039",
        ".ds-.logs-deprecation.elasticsearch-default-2023.04.21-000036",
        ".ds-.logs-deprecation.elasticsearch-default-2022.03.25-000008",
        ".ds-.logs-deprecation.elasticsearch-default-2023.02.24-000032",
        ".ds-.logs-deprecation.elasticsearch-default-2022.01.28-000004",
        ".ds-.logs-deprecation.elasticsearch-default-000001",
        ".ds-.logs-deprecation.elasticsearch-default-2022.07.29-000017",
        ".ds-.logs-deprecation.elasticsearch-default-2022.08.12-000018",
        ".ds-.logs-deprecation.elasticsearch-default-2022.11.04-000024",
        ".ds-.logs-deprecation.elasticsearch-default-2022.01.14-000003",
        ".ds-.logs-deprecation.elasticsearch-default-2023.08.25-000045",
        ".ds-.logs-deprecation.elasticsearch-default-2023.04.07-000035",
        ".ds-.logs-deprecation.elasticsearch-default-2022.02.11-000005",
        ".ds-.logs-deprecation.elasticsearch-default-2021.12.31-000002",
        ".ds-.logs-deprecation.elasticsearch-default-2023.01.13-000029",
        ".ds-.logs-deprecation.elasticsearch-default-2022.12.16-000027",
        ".ds-.logs-deprecation.elasticsearch-default-2023.06.30-000041",
        ".ds-.logs-deprecation.elasticsearch-default-2023.02.10-000031",
        ".ds-.logs-deprecation.elasticsearch-default-2022.09.23-000021",
        ".ds-.logs-deprecation.elasticsearch-default-2022.05.06-000011",
        ".ds-.logs-deprecation.elasticsearch-default-2022.12.02-000026",
        ".ds-.logs-deprecation.elasticsearch-default-2023.06.16-000040",
        ".ds-.logs-deprecation.elasticsearch-default-2023.05.19-000038",
        ".ds-.logs-deprecation.elasticsearch-default-2022.08.26-000019"
      "data_streams" : [
        ".logs-deprecation.elasticsearch-default"
        ".deprecation-indexing-template"
  ".fleet-actions-results-ilm-policy" : {
    "version" : 1,
    "modified_date" : "2021-12-17T03:46:01.697Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_size" : "300gb",
              "max_age" : "30d"
        "delete" : {
          "min_age" : "90d",
          "actions" : {
            "delete" : {
              "delete_searchable_snapshot" : true
    "in_use_by" : {
      "indices" : [ ],
  ".items-default" : {
    "version" : 1,
    "modified_date" : "2021-06-24T03:16:02.726Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_size" : "50gb"
    "in_use_by" : {
      "indices" : [
        ".items-default-000001"
  ".lists-default" : {
    "version" : 1,
    "modified_date" : "2021-06-24T03:16:02.503Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_size" : "50gb"
    "in_use_by" : {
      "indices" : [
        ".lists-default-000001"
  "180-days-default" : {
    "version" : 1,
    "modified_date" : "2021-12-17T03:55:16.616Z",
    "policy" : {
      "phases" : {
        "warm" : {
          "min_age" : "2d",
          "actions" : {
            "forcemerge" : {
              "max_num_segments" : 1
            "shrink" : {
              "number_of_shards" : 1
        "cold" : {
          "min_age" : "30d",
          "actions" : { }
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
        "delete" : {
          "min_age" : "180d",
          "actions" : {
            "delete" : {
      "_meta" : {
        "description" : "built-in ILM policy using the hot, warm, and cold phases with a retention of 180 days",
        "managed" : true
    "in_use_by" : {
      "indices" : [ ],
  "30-days-default" : {
    "version" : 14,
    "modified_date" : "2023-07-24T07:37:06.073Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "set_priority" : {
              "priority" : 100
        "delete" : {
          "min_age" : "60d",
          "actions" : {
            "delete" : {
        "warm" : {
          "min_age" : "2d",
          "actions" : {
            "allocate" : {
              "number_of_replicas" : 1,
              "include" : { },
              "exclude" : { },
              "require" : { }
            "set_priority" : {
              "priority" : 50
      "_meta" : {
        "description" : "built-in ILM policy using the hot and warm phases with a retention of 30 days",
        "managed" : true
    "in_use_by" : {
      "indices" : [
        "filebeat-d-prod-2023.08.13",
        "filebeat-d-prod-2023.08.14",
        "filebeat-d-prod-2023.08.12",
        "filebeat-s-prod-2023.09.08",
        "filebeat-s-prod-2023.09.06",
        "filebeat-s-prod-2023.09.07",
        "filebeat-s-prod-2023.08.13",
        "filebeat-s-prod-2023.08.12",
        "filebeat-s-prod-2023.08.15",
        "filebeat-s-prod-2023.08.14",
        "filebeat-d-prod-2023.09.07",
        "filebeat-d-prod-2023.09.08",
        "filebeat-d-prod-2023.09.05",
        "filebeat-d-prod-2023.09.06",
        "filebeat-s-prod-2023.08.20",
        "filebeat-d-prod-2023.08.31",
        "filebeat-s-prod-2023.08.22",
        "filebeat-s-prod-2023.08.21",
        "filebeat-d-prod-2023.08.30",
        "filebeat-s-prod-2023.08.24",
        "filebeat-d-prod-2023.09.03",
        "filebeat-d-prod-2023.09.04",
        "filebeat-s-prod-2023.08.23",
        "filebeat-s-prod-2023.08.26",
        "filebeat-d-prod-2023.09.01",
        "filebeat-d-prod-2023.09.02",
        "filebeat-s-prod-2023.08.25",
        "filebeat-s-prod-2023.08.17",
        "filebeat-d-prod-2023.08.28",
        "filebeat-s-prod-2023.08.16",
        "filebeat-d-prod-2023.08.29",
        "filebeat-s-prod-2023.08.19",
        "filebeat-d-prod-2023.08.26",
        "filebeat-s-prod-2023.08.18",
        "filebeat-d-prod-2023.08.27",
        "filebeat-d-prod-2023.08.20",
        "filebeat-s-prod-2023.08.31",
        "filebeat-d-prod-2023.08.21",
        "filebeat-s-prod-2023.09.01",
        "filebeat-s-prod-2023.08.30",
        "filebeat-s-prod-2023.09.04",
        "filebeat-d-prod-2023.08.24",
        "filebeat-s-prod-2023.09.05",
        "filebeat-d-prod-2023.08.25",
        "filebeat-s-prod-2023.09.02",
        "filebeat-d-prod-2023.08.22",
        "filebeat-d-prod-2023.08.23",
        "filebeat-s-prod-2023.09.03",
        "filebeat-s-prod-2023.08.28",
        "filebeat-d-prod-2023.08.17",
        "filebeat-d-prod-2023.08.18",
        "filebeat-s-prod-2023.08.27",
        "filebeat-d-prod-2023.08.15",
        "filebeat-s-prod-2023.08.29",
        "filebeat-d-prod-2023.08.16",
        "filebeat-d-prod-2023.08.19"
  "365-days-default" : {
    "version" : 1,
    "modified_date" : "2021-12-17T03:55:17.230Z",
    "policy" : {
      "phases" : {
        "warm" : {
          "min_age" : "2d",
          "actions" : {
            "forcemerge" : {
            "shrink" : {
        "cold" : {
          "min_age" : "30d",
          "actions" : { }
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
        "delete" : {
          "min_age" : "365d",
          "actions" : {
            "delete" : {
      "_meta" : {
        "description" : "built-in ILM policy using the hot, warm, and cold phases with a retention of 365 days",
        "managed" : true
    "in_use_by" : {
      "indices" : [ ],
  "60-days-default" : {
    "version" : 10,
    "modified_date" : "2023-08-30T07:47:42.759Z",
    "policy" : {
      "phases" : {
        "warm" : {
          "min_age" : "7d",
          "actions" : {
            "set_priority" : {
              "priority" : 50
            "shrink" : {
              "number_of_shards" : 2
        "cold" : {
          "min_age" : "14d",
          "actions" : {
            "set_priority" : {
              "priority" : 0
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_primary_shard_size" : "100gb",
              "max_age" : "40d"
            "set_priority" : {
              "priority" : 100
        "delete" : {
          "min_age" : "60d",
          "actions" : {
            "delete" : {
      "_meta" : {
        "managed" : true
    "in_use_by" : {
      "indices" : [ ],
  "7-days-default" : {
    "version" : 6,
    "modified_date" : "2023-04-03T03:07:52.087Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : { }
        "delete" : {
          "min_age" : "3d",
          "actions" : {
            "delete" : {
        "warm" : {
          "min_age" : "1d",
          "actions" : {
            "forcemerge" : {
            "readonly" : { },
            "set_priority" : {
              "priority" : 50
      "_meta" : {
        "description" : "built-in ILM policy using the hot and warm phases with a retention of 7 days",
        "managed" : true
    "in_use_by" : {
      "indices" : [
        "events-metricbeat-2023.09.08",
        "events-metricbeat-2023.09.06",
        "events-metricbeat-2023.09.07"
        "events-metricbeat"
  "90-days-default" : {
    "version" : 1,
    "modified_date" : "2021-12-17T03:55:16.920Z",
    "policy" : {
      "phases" : {
        "warm" : {
          "min_age" : "2d",
          "actions" : {
            "forcemerge" : {
            "shrink" : {
        "cold" : {
          "min_age" : "30d",
          "actions" : { }
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
        "delete" : {
          "min_age" : "90d",
          "actions" : {
            "delete" : {
      "_meta" : {
        "description" : "built-in ILM policy using the hot, warm, and cold phases with a retention of 90 days",
        "managed" : true
    "in_use_by" : {
      "indices" : [ ],
  "application_custom__policy" : {
    "version" : 20,
    "modified_date" : "2023-08-18T08:20:29.350Z",
    "policy" : {
      "phases" : {
        "warm" : {
          "min_age" : "2d",
          "actions" : {
            "allocate" : {
              "include" : { },
              "exclude" : { },
              "require" : { }
            "set_priority" : {
              "priority" : 50
        "cold" : {
          "min_age" : "30d",
          "actions" : {
            "set_priority" : {
              "priority" : 0
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "set_priority" : {
              "priority" : 100
        "delete" : {
          "min_age" : "60d",
          "actions" : {
            "delete" : {
    "in_use_by" : {
      "indices" : [ ],
  "ilm-history-ilm-policy" : {
    "version" : 1,
    "modified_date" : "2020-10-29T06:45:12.538Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_size" : "50gb",
              "max_age" : "30d"
        "delete" : {
          "min_age" : "90d",
          "actions" : {
            "delete" : {
    "in_use_by" : {
      "indices" : [
        ".ds-ilm-history-5-2023.08.09-000038",
        ".ds-ilm-history-5-2023.09.08-000039",
        "ilm-history-2-000035",
        "ilm-history-2-000034",
        ".ds-ilm-history-5-2023.07.10-000035",
        "ilm-history-2-000033",
        "ilm-history-2-000032",
        ".ds-ilm-history-5-2023.06.10-000034"
      "data_streams" : [
        "ilm-history-5"
        "ilm-history"
  "kibana-event-log-policy" : {
    "version" : 1,
    "modified_date" : "2020-10-29T10:47:15.943Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
        "delete" : {
          "min_age" : "90d",
          "actions" : {
            "delete" : {
    "in_use_by" : {
      "indices" : [
        ".kibana-event-log-7.9.3-000035",
        ".kibana-event-log-7.16.1-000019",
        ".kibana-event-log-7.9.3-000034",
        ".kibana-event-log-7.9.3-000033",
        ".kibana-event-log-7.9.3-000032",
        ".kibana-event-log-7.16.2-000018",
        ".kibana-event-log-7.16.2-000017",
        ".kibana-event-log-7.16.2-000019",
        ".kibana-event-log-7.16.1-000022",
        ".kibana-event-log-7.16.1-000021",
        ".kibana-event-log-7.16.1-000020",
        ".kibana-event-log-7.16.2-000016"
        ".kibana-event-log-7.16.1-template",
        ".kibana-event-log-7.16.2-template"
  "kibana-reporting" : {
    "version" : 1,
    "modified_date" : "2021-12-17T04:35:08.935Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : { }
    "in_use_by" : {
      "indices" : [
        ".reporting-2023-09-03",
        ".reporting-2022-10-23",
        ".reporting-2022-12-04",
        ".reporting-2022-05-29",
        ".reporting-2023-03-12",
        ".reporting-2022-04-17",
        ".reporting-2023-06-04",
        ".reporting-2023-04-23",
        ".reporting-2022-01-23",
        ".reporting-2023-08-20",
        ".reporting-2023-08-27",
        ".reporting-2023-07-16",
        ".reporting-2023-02-19",
        ".reporting-2022-10-30",
        ".reporting-2023-01-08",
        ".reporting-2022-12-11",
        ".reporting-2022-02-20",
        ".reporting-2022-06-26",
        ".reporting-2023-01-01",
        ".reporting-2022-09-18",
        ".reporting-2023-03-26",
        ".reporting-2022-05-15",
        ".reporting-2023-02-12",
        ".reporting-2022-07-31",
        ".reporting-2022-02-27",
        ".reporting-2022-09-11",
        ".reporting-2023-04-30",
        ".reporting-2023-08-13",
        ".reporting-2022-11-13",
        ".reporting-2023-04-09",
        ".reporting-2022-10-09",
        ".reporting-2023-02-26",
        ".reporting-2023-01-15",
        ".reporting-2023-04-02",
        ".reporting-2023-05-14",
        ".reporting-2023-06-25",
        ".reporting-2022-07-24",
        ".reporting-2022-05-01",
        ".reporting-2023-08-06",
        ".reporting-2022-11-20",
        ".reporting-2021-12-19",
        ".reporting-2023-01-29",
        ".reporting-2023-03-05",
        ".reporting-2022-04-24",
        ".reporting-2022-03-13",
        ".reporting-2023-04-16",
        ".reporting-2022-06-05",
        ".reporting-2022-10-16",
        ".reporting-2022-11-27",
        ".reporting-2023-01-22",
        ".reporting-2022-02-06",
        ".reporting-2022-08-21",
        ".reporting-2022-07-10",
        ".reporting-2023-05-21"
  "logs" : {
    "version" : 1,
    "modified_date" : "2020-10-29T06:45:12.440Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
    "in_use_by" : {
      "indices" : [ ],
        "logs"
  "metricbeat" : {
    "version" : 2,
    "modified_date" : "2020-10-30T03:30:18.471Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
    "in_use_by" : {
      "indices" : [ ],
  "metrics" : {
    "version" : 1,
    "modified_date" : "2020-10-29T06:45:12.390Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
    "in_use_by" : {
      "indices" : [ ],
        "metrics"
  "ml-size-based-ilm-policy" : {
    "version" : 1,
    "modified_date" : "2020-10-29T06:45:12.326Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_size" : "50gb"
    "in_use_by" : {
      "indices" : [ ],
        ".ml-state",
        ".ml-stats"
  "slm-history-ilm-policy" : {
    "version" : 1,
    "modified_date" : "2020-10-29T06:45:12.588Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
        "delete" : {
          "min_age" : "90d",
          "actions" : {
            "delete" : {
    "in_use_by" : {
      "indices" : [ ],
        ".slm-history"
  "synthetics" : {
    "version" : 1,
    "modified_date" : "2021-12-17T03:55:17.065Z",
    "policy" : {
      "phases" : {
        "hot" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "30d"
      "_meta" : {
        "description" : "default policy for the synthetics index template installed by x-pack",
        "managed" : true
    "in_use_by" : {
      "indices" : [ ],
        "synthetics"
  "watch-history-ilm-policy" : {
    "version" : 1,
    "modified_date" : "2020-10-29T06:45:12.483Z",
    "policy" : {
      "phases" : {
        "delete" : {
          "min_age" : "7d",
          "actions" : {
            "delete" : {
    "in_use_by" : {
      "indices" : [ ],
        ".watch-history-13"
