I've got a confusing issue when using index lifecycle management feature in ES and filebeat.
I'm collecting logs from various pods in K8S using filebeat, and sending them to Elasticsearch, I have a few requirements listed below:
- index pattern should be
log-{k8s.namespace}-{time}, wherek8s.namespaceis the kubernetes namespace of the pod the log comes from. Therefore different log might have different index in ES - All the fields in logs should be treated as keyword in ES so that they could be searched as a whole, so I have a template.json used for index template listed below
- the index should be automatically deleted after 7 days from creation. (where ILM is used for)
so I have a filebeat.yml configuration like this (irrelevant fields are omitted):
setup.template.overwrite: true
setup.template.json.enabled: true
setup.template.json.path: "template.json"
setup.template.json.name: "log"
setup.ilm.enabled: auto
setup.ilm.rollover_alias: "log-rollover"
setup.ilm.pattern: "-000001"
output.elasticsearch:
indices:
- index: "%{[kubernetes.namespace]}-%{+yyyy.MM.dd}"
when.has_fields:
- "kubernetes.namespace"
- index: "default-%{+yyyy.MM.dd}"
and the template.json file: (irrelevant fields omitted)
"order": 0,
"index_patterns": [
"log-*"
"settings": {
"index": {
"number_of_shards": "7",
"number_of_replicas": "1",
"refresh_interval": "60s",
"lifecycle.name": "log-policy",
"lifecycle.rollover_alias": "log-rollover"
I've also got an ILM policy already set in ES, which has the name log-policy corresponding to the name above.
After I set all these, I got the error:
illegal_argument_exception: index.lifecycle.rollover_alias [log-rollover] does not point to index
I know this is because the alias should be created before the first index.
So my question is:
- in my filebeat.yml, there is
setup.ilm.rollover_alias: "log-rollover", why doesn't it create the alias for me? If it doesn't what else config can ? - what is
setup.ilm.patternused for? It seems this config doesn't control the index pattern sent to ES cuz I didn't see this pattern in ES. - I'm aware that if
setup.ilm.enabled: autois set, theindicesmight be ignored, so in this situation (ILM enabled), what config should I use to set flexible index pattern likeindices? I need those two indices in case some logs might not have akubernetes.namespacefield. - in both template.json and filebeat.yml there can be
setup.ilm.rollover_aliasandsetup.ilm.nameconfigs, if both set, which one would be used ?
can anyone help me...please.. I've been struggling for a few days already...
