Es.index.read.missing.as.empty seems not working with multiple indices?
I am using ES Hadoop Spark plugin.
I have set and am running the following...
val conf = new SparkConf()
  .setAppName(this.getClass.getSimpleName)
  .set("spark.app.id", "1")
  .set("es.nodes", ConfigHelper.elasticHost)
  .set("es.index.read.missing.as.empty", "yes")
val sc = new SparkContext(conf)
sc.esJsonRDD("index1, index2", queryString)
And it throws
[index2] IndexNotFoundException[no such index]
	at org.elasticsearch.cluster.metadata.IndexNameExpressionResolver$WildcardExpressionResolver.resolve(IndexNameExpressionResolver.java:586)
	at org.elasticsearch.cluster.metadata.IndexNameExpressionResolver.concreteIndices(IndexNameExpressionResolver.java:133)
	at org.elasticsearch.cluster.metadata.IndexNameExpressionResolver.concreteIndices(IndexNameExpressionResolver.java:113)
	at org.elasticsearch.action.search.type.TransportSearchTypeAction$BaseAsyncAction.<init>(TransportSearchTypeAction.java:121)
	at org.elasticsearch.action.search.type.TransportSearchQueryThenFetchAction$AsyncAction.<init>(TransportSearchQueryThenFetchAction.java:73)
	at org.elasticsearch.action.search.type.TransportSearchQueryThenFetchAction$AsyncAction.<init>(TransportSearchQueryThenFetchAction.java:67)
	at org.elasticsearch.action.search.type.TransportSearchQueryThenFetchAction.doExecute(TransportSearchQueryThenFetchAction.java:64)
	at org.elasticsearch.action.search.type.TransportSearchQueryThenFetchAction.doExecute(TransportSearchQueryThenFetchAction.java:53)
	at org.elasticsearch.action.support.TransportAction.execute(TransportAction.java:70)
	at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:99)
	at org.elasticsearch.action.search.TransportSearchAction.doExecute(TransportSearchAction.java:44)
	at org.elasticsearch.action.support.HandledTransportAction$TransportHandler.messageReceived(HandledTransportAction.java:45)
	at org.elasticsearch.action.support.HandledTransportAction$TransportHandler.messageReceived(HandledTransportAction.java:41)
	at org.elasticsearch.transport.netty.MessageChannelHandler.handleRequest(MessageChannelHandler.java:244)
	at org.elasticsearch.transport.netty.MessageChannelHandler.messageReceived(MessageChannelHandler.java:114)
	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70)
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564)
	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:296)
	at org.jboss.netty.handler.codec.frame.FrameDecoder.unfoldAndFireMessageReceived(FrameDecoder.java:462)
	at org.jboss.netty.handler.codec.frame.FrameDecoder.callDecode(FrameDecoder.java:443)
	at org.jboss.netty.handler.codec.frame.FrameDecoder.messageReceived(FrameDecoder.java:303)
	at org.elasticsearch.common.netty.OpenChannelsHandler.handleUpstream(OpenChannelsHandler.java:75)
	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268)
	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255)
	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88)
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108)
	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337)
	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89)
	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178)
	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108)
	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Weird...
Wouldn't ("es.index.read.missing.as.empty", "yes") make it not throwing the exception?
I've even tried with ("es.index.read.missing.as.empty", "true"), and it throws the same.
Any idea?
Do you get the exception with your spark app or not? The setting is only available in ES-Hadoop to make it ignore non-existing indices.
The exception comes from the following line of code.
Isn't this from ES-Hadoop?
It does - wanted to verify. Can you please raise an issue - it looks like a bug. Thanks!
