Hi all,
I looked around and couldn't find an answer for this weird exception I've been getting half-way through the indexing of about 1M documents(each one has an ID field and a phonenumbers field):
Failed to perform indices/index/shard/index on replica Index Shard [panda][2]org.elasticsearch.transport.RemoteTransportException: [Quicksilver][inet[/192.168.7.216:9300]][indices/index/shard/index/repl
ica]Caused by: org.elasticsearch.index.engine.IndexFailedEngineException: [panda][2] Index failed for [phonenumber#9-25987-27d8a1
ce-98c7-456b-a]
at org.elasticsearch.index.engine.robin.RobinEngine.index(RobinEngine.java:329)
at org.elasticsearch.index.shard.service.InternalIndexShard.index(InternalIndexShard.java:284)
at org.elasticsearch.action.index.TransportIndexAction.shardOperationOnReplica(TransportIndexAction.java:227) at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$ReplicaOperationTransportHan
dler.messageReceived(TransportShardReplicationOperationAction.java:202) at org.elasticsearch.action.support.replication.TransportShardReplicationOperationAction$ReplicaOperationTransportHan
dler.messageReceived(TransportShardReplicationOperationAction.java:191)
at org.elasticsearch.transport.netty.MessageChannelHandler$RequestHandler.run(MessageChannelHandler.java:238)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.io.IOException: No space left on device
at java.io.RandomAccessFile.writeBytes(Native Method)
at java.io.RandomAccessFile.write(RandomAccessFile.java:466)
at org.apache.lucene.store.SimpleFSDirectory$SimpleFSIndexOutput.flushBuffer(SimpleFSDirectory.java:187)
at org.apache.lucene.store.BufferedIndexOutput.flushBuffer(BufferedIndexOutput.java:99)
at org.apache.lucene.store.BufferedIndexOutput.flush(BufferedIndexOutput.java:88)
at org.apache.lucene.store.BufferedIndexOutput.writeBytes(BufferedIndexOutput.java:77)
at org.elasticsearch.index.store.support.AbstractStore$StoreIndexOutput.writeBytes(AbstractStore.java:350)
at org.apache.lucene.store.IndexOutput.writeBytes(IndexOutput.java:43)
at org.apache.lucene.store.RAMOutputStream.writeTo(RAMOutputStream.java:66)
at org.apache.lucene.index.FieldsWriter.flushDocument(FieldsWriter.java:129)
at org.apache.lucene.index.StoredFieldsWriter.finishDocument(StoredFieldsWriter.java:149)
at org.apache.lucene.index.StoredFieldsWriter$PerDoc.finish(StoredFieldsWriter.java:192)
at org.apache.lucene.index.DocumentsWriter$WaitQueue.writeDocument(DocumentsWriter.java:1559)
at org.apache.lucene.index.DocumentsWriter$WaitQueue.add(DocumentsWriter.java:1578)
at org.apache.lucene.index.DocumentsWriter.finishDocument(DocumentsWriter.java:1155)
at org.apache.lucene.index.DocumentsWriter.updateDocument(DocumentsWriter.java:832)
at org.apache.lucene.index.DocumentsWriter.addDocument(DocumentsWriter.java:802)
at org.apache.lucene.index.IndexWriter.addDocument(IndexWriter.java:1998)
at org.elasticsearch.index.engine.robin.RobinEngine.innerIndex(RobinEngine.java:391)
at org.elasticsearch.index.engine.robin.RobinEngine.index(RobinEngine.java:322)
... 8 more
[2011-04-10 20:27:33,959][WARN ][cluster.action.shard ] [Hela] sending failed shard for [panda][2], node[iIe-oUNfQ26UcWVBbv9O-Q], [R], s[STARTED], reason [Failed to perform [indices/index/shard/index] on replica, message [RemoteTransportException[[Quicksilver][inet[/192.168.7.216:9300]][indices/index/shard/index/replica]]; nested: IndexFailedEngineException[[panda][2] Index failed for [phonenumber#9-25987-27d8a1ce-98c7-456b-a]]; nested: IOException[No space left on device]; ]]
The index got only around 2G and the exception was very misleading 'cause I've more than enough space left.
I downloaded the ES server, ran as it is (w/ a blank elasticsearch.yml file) and had ulimit set to 64000. Any pointers? Thank a lot!!
