I am getting this error while running kibana and inspecting kibana logs with
journalctl -u kibana
I am starting kibana with
sudo systemctl start kibana
Kibana version 7.10
link to my kibana.yml
/var/log journalctl -u kibana ✔
-- Journal begins at Mon 2021-06-07 14:49:48 IST, ends at Wed 2021-06-23 18:42:55 IST. --
Jun 08 09:39:28 friday systemd[1]: Started Kibana - dashboard for Elasticsearch.
Jun 08 09:40:52 friday node[871]: FATAL CLI ERROR YAMLException: can not read a block mapping entry; a multiline key may not be an implicit key at line 32, column 1:
Jun 08 09:40:52 friday node[871]: # Kibana uses an index in Elasti ...
Jun 08 09:40:52 friday node[871]: ^
Jun 08 09:40:52 friday node[871]: at generateError (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:167:10)
Jun 08 09:40:52 friday node[871]: at throwError (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:173:9)
Jun 08 09:40:52 friday node[871]: at readBlockMapping (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:1073:9)
Jun 08 09:40:52 friday node[871]: at composeNode (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:1359:12)
Jun 08 09:40:52 friday node[871]: at readDocument (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:1525:3)
Jun 08 09:40:52 friday node[871]: at loadDocuments (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:1588:5)
Jun 08 09:40:52 friday node[871]: at load (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:1614:19)
Jun 08 09:40:52 friday node[871]: at Object.safeLoad (/usr/share/kibana/node_modules/js-yaml/lib/js-yaml/loader.js:1637:10)
Jun 08 09:40:52 friday node[871]: at readYaml (/usr/share/kibana/node_modules/@kbn/config/target/raw/read_config.js:27:38)
Jun 08 09:40:52 friday node[871]: at Object.exports.getConfigFromFiles (/usr/share/kibana/node_modules/@kbn/config/target/raw/read_config.js:52:22)
Jun 08 09:40:52 friday systemd[1]: kibana.service: Main process exited, code=exited, status=1/FAILURE
Jun 08 09:40:52 friday systemd[1]: kibana.service: Failed with result 'exit-code'.
Jun 08 09:40:52 friday systemd[1]: kibana.service: Scheduled restart job, restart counter is at 1.
This is the complete error
