Hi all,
I am trying to get data from MISP using filebeat but i am having trouble making filebeat work because it doesn't want to establish connection to MISP due to it being self signed.
Things i have tried:
In Filebeat.yml
ssl.verification_mode: "none"
This did not do anything.
In Filebeat Misp Module:
var.ssl.verification_mode: "none" or var.ssl.verification_mode: none
Gives the error:
2020-04-30T09:39:53.962+0700 ERROR instance/beat.go:933 Exiting: (assert) value of type 'string' not convertible into unsupported go type 'tlscommon.Config' accessing 'ssl'
Trace:goroutine 1 [running]:
runtime/debug.Stack(0x32ef81f, 0xb, 0xc000936078)
/usr/local/go/src/runtime/debug/stack.go:24 +0x9d
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.raiseCritical(0x36e3760, 0xc0000e90b0, 0xc0002b2460, 0x6b, 0x52, 0xc0007bd498)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/error.go:153 +0x66
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.raiseToTypeNotSupported(0xc00015fb80, 0x378b660, 0xc000448fc0, 0x37a75c0, 0x31a8040, 0x2e7dea0, 0x0)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/error.go:286 +0x232
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.doReifyPrimitive(0xc00015fb80, 0x0, 0x0, 0x0, 0x0, 0x378b660, 0xc000448fc0, 0x37a75c0, 0x31a8040, 0x18304db, ...)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:729 +0x89c
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.reifyPrimitive(0xc00015fb80, 0x0, 0x0, 0x0, 0x0, 0x378b660, 0xc000448fc0, 0x37a75c0, 0x2f8fea0, 0x37a75c0, ...)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:631 +0x5fb
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.reifyValue(0xc00015fb80, 0x0, 0x0, 0x0, 0x0, 0x37a75c0, 0x2f8fea0, 0x378b660, 0xc000448fc0, 0xc0008e7d70, ...)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:360 +0x990
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.reifyMergeValue(0xc00015fb80, 0x0, 0x0, 0x0, 0x0, 0x2f8fea0, 0xc00025dda8, 0x196, 0x378b660, 0xc000448fc0, ...)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:410 +0xfbf
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.reifyGetField(0xc00064f680, 0xc00015fb80, 0x0, 0x0, 0x0, 0x0, 0x2d0c320, 0x3, 0x2f8fea0, 0xc00025dda8, ...)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:318 +0x248
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.reifyStruct(0xc00015fb80, 0x31fba20, 0xc00025dce0, 0x199, 0xc00064f680, 0x0, 0x0)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:281 +0x5e0
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.reifyInto(0xc00015fb80, 0x2f4b640, 0xc00025dce0, 0x16, 0xc00064f680, 0x70, 0x31fba20)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:161 +0x3fb
github.com/elastic/beats/vendor/github.com/elastic/go-ucfg.(*Config).Unpack(0xc00064f680, 0x2f4b640, 0xc00025dce0, 0xc000568a00, 0x4, 0x4, 0x10, 0xc000936c28)
/go/src/github.com/elastic/beats/vendor/github.com/elastic/go-ucfg/reify.go:144 +0x103
github.com/elastic/beats/libbeat/common.(*Config).Unpack(...)
/go/src/github.com/elastic/beats/libbeat/common/config.go:168
github.com/elastic/beats/x-pack/filebeat/input/httpjson.NewInput(0xc00064f680, 0x37135a0, 0xc0007e4dc0, 0xc000630000, 0x72, 0x72, 0xc0008410e0, 0xc000840000, 0x0, 0x0, ...)
/go/src/github.com/elastic/beats/x-pack/filebeat/input/httpjson/input.go:67 +0xe5
github.com/elastic/beats/filebeat/input.New(0xc00064f680, 0x37135a0, 0xc0007e4dc0, 0xc000840000, 0xc000630000, 0x72, 0x72, 0x0, 0x0, 0x2f48798, ...)
/go/src/github.com/elastic/beats/filebeat/input/input.go:102 +0x392
github.com/elastic/beats/filebeat/fileset.(*Factory).Create(0xc000550000, 0x3733c20, 0xc0008dadc0, 0xc00099fa70, 0x0, 0x0, 0x4, 0x0, 0x0)
/go/src/github.com/elastic/beats/filebeat/fileset/factory.go:103 +0x2af
github.com/elastic/beats/libbeat/cfgfile.(*Reloader).Check(0xc000252cc0, 0x36e38a0, 0xc000550000, 0xc000252cc0, 0xc00061e000)
/go/src/github.com/elastic/beats/libbeat/cfgfile/reload.go:163 +0x2e6
github.com/elastic/beats/filebeat/crawler.(*Crawler).Start(0xc0006621b0, 0x3733c20, 0xc0008dadc0, 0xc0002527e0, 0x0, 0xc0002bb560, 0xc0001a7d90, 0xc00099a000, 0xc0002527e0, 0x0)
/go/src/github.com/elastic/beats/filebeat/crawler/crawler.go:97 +0x428
github.com/elastic/beats/filebeat/beater.(*Filebeat).Run(0xc0007038c0, 0xc000607440, 0x0, 0x0)
/go/src/github.com/elastic/beats/filebeat/beater/filebeat.go:375 +0xa9d
github.com/elastic/beats/libbeat/cmd/instance.(*Beat).launch(0xc000607440, 0x32eab08, 0x8, 0x32eab08, 0x8, 0x0, 0x0, 0x1, 0x0, 0x0, ...)
/go/src/github.com/elastic/beats/libbeat/cmd/instance/beat.go:445 +0x700
github.com/elastic/beats/libbeat/cmd/instance.Run.func1(0x32eab08, 0x8, 0x32eab08, 0x8, 0x0, 0x0, 0xc000b17c58, 0x33f0e98, 0x0, 0x0)
/go/src/github.com/elastic/beats/libbeat/cmd/instance/beat.go:188 +0x56b
github.com/elastic/beats/libbeat/cmd/instance.Run(0x32eab08, 0x8, 0x32eab08, 0x8, 0x0, 0x0, 0x1, 0x0, 0x0, 0x0, ...)
/go/src/github.com/elastic/beats/libbeat/cmd/instance/beat.go:189 +0x148
github.com/elastic/beats/libbeat/cmd.genRunCmd.func1(0xc000289680, 0xc0006fd830, 0x0, 0x9)
/go/src/github.com/elastic/beats/libbeat/cmd/run.go:36 +0x9d
github.com/elastic/beats/vendor/github.com/spf13/cobra.(*Command).execute(0xc000289680, 0xc00004e0b0, 0x9, 0x9, 0xc000289680, 0xc00004e0b0)
/go/src/github.com/elastic/beats/vendor/github.com/spf13/cobra/command.go:704 +0x285
github.com/elastic/beats/vendor/github.com/spf13/cobra.(*Command).ExecuteC(0xc000289680, 0x0, 0xd6e00, 0xc000116058)
/go/src/github.com/elastic/beats/vendor/github.com/spf13/cobra/command.go:785 +0x2c9
github.com/elastic/beats/vendor/github.com/spf13/cobra.(*Command).Execute(...)
/go/src/github.com/elastic/beats/vendor/github.com/spf13/cobra/command.go:738
main.main()
/go/src/github.com/elastic/beats/x-pack/filebeat/main.go:22 +0x2f
Thank You.
