Filter_path in POST Body
Hey,
the responses I get from Elastisearch are rather huge. I've found out that it is possible to remove data of responses by using response filtering:
Is there any way to put the filter inside a POST body so that I could use in a query like this:
window.fetch(Config.serverUrl, {
      method: 'POST',
      mode: 'cors',
      body: JSON.stringify({
        'query': {
            'bool': {
              'should': [
                  'match': {
                    'type': 'GatewayClosed'
                  'match': {
                    'type': 'GatewayStarted'
        "size": 0,
        "aggregations": {
          "Gateways": {
            "terms": {
              "field": "source.keyword",
              "size": 10000
            "aggs": {
              "Information": {
                "top_hits": {
                  "sort": [
                      "@timestamp": {
                        "order": "desc"
                  "_source": {
                    "includes": ["source", "timestamp", "type"]
                  "size": 1
Hey,
the filter_path always must be a parameter and cannot be included in the body.
--Alex
Alright. Thank you.
