Fractional values are missing while using sum aggregation in metric
Fractional values are missing while using sum aggregation in metric,
How can I get the fractional values in metric by using sum / average aggregation?
Could you share a screenshot of your output? And could you also go to Inspect on the top of the screen, and share the tabular data and the response, that you're seeing there?
Hi Timroes,
Thanks for the response, Found the issue,
Issue in ElasticSearch index, my data field type instead of float its got changed to long.
