Grok timestamp help
Need help pls, whats the grok format for this kind of timestamp? also i would like to add the current date(e.g YYYY-MM-DD). to it
04:38:30.793UTC
My logs is like this.
sample log is like this:
05:08:33.351UTC DEBUG c.x.x.x.MapSsnActor MapSsnActor(akka://x) - create dialog request id=2767649
Here's my logstash filter
filter
if [host] == "ip-10-x-x-x" or [host] == "ip-x-3-x-x" {
grok {
match => [ "message", "%{TIME:logtime}%{TZ:tz} %{LOGLEVEL:level} %{GREEDYDATA:message}" ]
mutate {
add_field => { "timestamp" => "MMM dd YYYY %{logtime}%{tz}" }
date {
locale => "en"
timezone => "UTC"
match => ["timestamp", "MMM dd YYYY HH:mm:ss.SSSZZZ"]
target => "@timestamp"
this is what I tried:
  generator {
    count => 1
    message => "05:08:33.351UTC DEBUG c.emnify.esc.cmaprouter.MapSsnActor MapSsnActor(akka://esc) - create dialog request id=2767649"
  grok {
    match => ["message", "%{DATA:timestamp} .*"]
  date {
    match => ["timestamp", "HH:MM:ss.SSSZZZ"]
  stdout { codec => rubydebug }
This results in :
      "@version" => "1",
          "host" => "Joaos-MBP-5.lan",
      "sequence" => 0,
    "@timestamp" => 2017-08-01T05:00:33.351Z,
       "message" => "05:08:33.351UTC DEBUG c.emnify.esc.cmaprouter.MapSsnActor MapSsnActor(akka://esc) - create dialog request id=2767649",
     "timestamp" => "05:08:33.351UTC"
oh, thanks for the reply I'll try this and get back to you
Im still seeing different value on @timestamp
"_index": "maprouter-2017.10.13",
"_type": "log",
"_id": "AV8VPYbGtbGo0IPlJYxy",
"_version": 1,
"_score": null,
"_source": {
"message": "10:17:32.998UTC INFO a.r.RemoteActorRefProvider$RemotingTerminator akka.tcp://x@:50689/system/remoting-terminator - Remoting shut down.",
"@version": "1",
"@timestamp": "2017-10-13T10:17:34.466Z",
"offset": 2776538,
"type": "log",
"input_type": "log",
"beat": {
"name": "ip-10-x-x-x",
"hostname": "ip-10-x-x-x",
"version": "5.6.2"
"source": "/opt/esc/logs/cmaprouter101.log",
"host": "ip-10-3-101-15",
"tags": [
"beats_input_codec_plain_applied",
"_dateparsefailure"
"timestamp": "10:17:32.998UTC",
"@metadata": {
"fingerprint": {
"}": 1681251507
"fields": {
"@timestamp": [
1507889854466
"sort": [
1507889854466
Here's my filter btw.
if [type] == "syslog" {
grok {
match => { "message" => "%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:[%{POSINT:syslog_pid}])?: %{GREEDYDATA:syslog_message}" }
add_field => [ "received_at", "%{@timestamp}" ]
add_field => [ "received_from", "%{host}" ]
syslog_pri { }
date {
match => [ "syslog_timestamp", "MMM d HH:mm:ss", "MMM dd HH:mm:ss", "HH:mm:ss.SSSZZZ" ]
else if [type] == "log" {
grok {
date {
if "DEBUG" not in [message] and "WARN" not in [message] and "INFO" not in [message] and "ERROR" not in [message] {
drop { }
if "DEBUG o.m.protocols.sctp.AssociationImpl" in [message] {
drop { }
if [host] == "ip-10-x-x-x" or [host] == "ip-10-x-x-x" {
fingerprint {
source => "message"
target => "%{[@metadata][fingerprint]}"
method => "MURMUR3"
Because the date filter is wrong.
date {
Try
https://www.elastic.co/guide/en/logstash/current/plugins-filters-date.html
date {
match => ["timestamp", "HH:mm:ss.SSSZZZ"]
oh i see, thanks i'll try this
Hi
when i change MM to mm, it seems it doesnt work. No more timestamp field.
"_index": "x-2017.10.13",
"_type": "log",
"_id": "AV8VYhs8tbGo0IPlJrka",
"_version": 1,
"_score": null,
"_source": {
"message": " DEBUG c.x.x.x.x x x-router - initializing SCTP stack ...",
"@version": "1",
"@timestamp": "2017-10-13T10:57:47.313Z",
"offset": 3012936,
"type": "log",
"beat": {
"version": "5.6.2"
"host": "ip-10-x-x-x",
"tags": [
"@metadata": {
"fingerprint": {
"}": 3017888107
"fields": {
"@timestamp": [
1507892267313
"sort": [
1507892267313
filter:
grok {
syslog_pri { }
date {
grok {
date {
drop { }
drop { }
fingerprint {
source => "message"
method => "MURMUR3"
Hi I'm having this error
{:timestamp=>"2017-10-13T11:08:15.589000+0000", :message=>"Failed parsing date from field", :field=>"timestamp", :value=>"00:", :exception=>"Invalid format: "00:" is too short", :config_parsers=>"HH:mm:ss.SSSZZZ", :config_locale=>"default=en_US", :level=>:warn}
In this message the timestamp field has a different format, which means you have events with different timestamp formats too?
Hello jsvd
Im now seeing logs but im having wrong year(2017.01.01) which also ships on wring index. How can i correct this, appreciated your help thanks
   "message" => "05:52:28.773UTC DEBUG akka.cluster.ClusterCoreDaemon akka.tcp://1/system/cluster/core/daemon   - Cluster Node [akka.tcp://] - Receiving gossip from [UniqueAddress(akka.tcp://esc@x:41599,-2133981790)]",
  "@version" => "1",
**"@timestamp" => "2017-01-01T05:52:28.773Z",**
    "source" => "/opt/x/logs/x.log",
    "offset" => 1544114,
      "type" => "applog",
"input_type" => "log",
      "beat" => {
        "name" => "ip-10-x-x-x",
    "hostname" => "ip-10-x-x-x",
     "version" => "5.6.2"
      "host" => "ip-10-x-x-x",
      "tags" => [
    [0] "beats_input_codec_plain_applied"
 "timestamp" => [
    [0] "05:52:28.773UTC",
    [1] "05:52:28.773UTC"
    "@metadata" => {
        "fingerprint" => {
            "}" => 2596617487
Hello
I've tried to use this
ruby {
code => "
event['date'] = Time.now.strftime('%Y-%m-%d')
But im having below error for logstash 5.6
[2017-10-14T08:01:18,237][ERROR][logstash.filters.ruby ] Ruby exception occurred: Direct event field references (i.e. event['field'] = 'value') have been disabled in favor of using event get and set methods (e.g. event.set('field', 'value')). Please consult the Logstash 5.0 breaking changes documentation for more details.
Hi
I was able to get the correct event api for current date in logstash 5.6. but now my date wont match. Date(YYYY-MM-dd) so i'm having incorrect index with date(2017.01.01). See below
filter:
if "UTC " in [message] {
ruby {
code => "
event.set('dateko', Time.now.strftime('%Y-%m-%d'))
mutate {
add_field => {
"akkatimestamp" => "%{dateko} %{timestampko}"
remove_field => ["timestampko"]
date {
match => [ "akkatimestamp", "YYYY-MM-dd HH:mm:ss.SSSZZZ", "yyyy-MM-dd HH:mm:ss.SSSZZZ" ]
ES:
"_index": "maprouter-applog-2017.01.01",
"_type": "applog",
"_id": "%{[@metadata][fingerprint]}",
"_version": 96960,
"_score": null,
"_source": {
"dateko": "2017-10-15",
"syslog_severity_code": 5,
"offset": 24718,
"syslog_facility": "user-level",
"syslog_facility_code": 1,
"newtimestamp": "%{date} 06:42:20.488UTC",
"source": "/maplogs/logs/maprouter001.log",
"message": "06:42:20.488UTC DEBUG c.x.x.x.MapSsnActor MapSsnActor(akka://esc) - endDialog id=5222641",
"type": "applog",
"syslog_severity": "notice",
"tags": [
"applogs",
"_grokparsefailure",
"_rubyexception",
"_dateparsefailure"
"akkatimestamp": "2017-10-15 06:42:20.488UTC",
"@timestamp": "2017-01-01T06:42:20.488Z",
"@metadata": {
"fingerprint": {
"}": 1689888401
"@version": "1",
"beat": {
"version": "5.6.2"
"timestamp": "06:42:20.488UTC"
"fields": {
"@timestamp": [
1483252940488
"sort": [
1483252940488
Pls help
Im having hard time to know why i received the logs with a @timestamp": "2017-01-01T14:03:42.082Z which should not be the case. as you can see from below ES data, "received_at": "2017-10-15T14:07:04.635Z", but my default date appearing is 2017.01.01. how this can be? it's also affecting the index, which also wrong, even my date filter doesnt work. (see above logstash config)
"_index": "x-x-x-2017.01.01",
"_type": "applog",
"_version": 2350,
"_score": null,
"_source": {
"offset": 324791,
"newtimestamp": "%{date} 14:03:42.082UTC",
"message": "14:03:42.082UTC DEBUG c.x.x.cmaprouter.MapSsnActor MapSsnActor(akka://esc) - endDialog id=6086010",
"type": "applog",
"tags": [
"applogs",
"_rubyexception",
"_dateparsefailure"
"akkatimestamp": "2017-10-15.14:03:42.082UTC",
"received_from": "ip-10-x-x-x",
"@timestamp": "2017-01-01T14:03:42.082Z",
"@metadata": {
"fingerprint": {
"}": 2008906984
"@version": "1",
"beat": {
"version": "5.6.2"
"timestamp": "14:03:42.082UTC"
"fields": {
"received_at": [
1508076424635
"@timestamp": [
1483279422082
"dateko": [
1508025600000
"sort": [
1483279422082
Hello
Appreciate any assistance
I've already fixed this :slight_smile:
it's because of this ""_id": "%{[@metadata][fingerprint]}","
