The port and host are 9200 and localhost by default. What's your ES
version?
ES-Hadoop requires 0.90 or higher (preferably the latest 0.90).
On 04/02/2014 12:59 PM, Phil gib wrote:
Hello Costin,
changing to "es.resource" does not help...
argh.. i see the socket connection closed in the ES logs.. so ES is
contacted ... the 9200 is correct ?
philippe
best regards
 configuration.set("es.resource", "eshindex2/eshlog2/_search?q=*");
     configuration.set("es.host", "localhost");
     configuration.set("es.port", "9200");
     System.out.println("conf:"+ configuration);
     JobConf job = new JobConf(configuration,
SimpleJobES2Hadoop.class);
On Tuesday, February 4, 2014 11:07:37 AM UTC+1, Costin Leau wrote:
If you are using M1 you should use es.resource instead of es.query
in your latest example.
es.query is supported in the upcoming 1.3.0.M2 (not in m1).
On 04/02/2014 12:01 PM, Phil gib wrote:
> hello my context:
>   ES 0.90.3,   elasticsearch-hadoop-1.3.0.M1 , eclipse- java
> i am experimenting ES->Hadoop  and Hadoop->ES
> no problem with Hadoop2ES  with these 3 settings  ( i see the
index + data  through head plugin, perfect)
> job.set("es.resource", "eshindex2/eshlog2");
> job.set("es.host", "localhost");
> job.set("es.port", "9200");
> but experimenting the inverse , ie ES 2 Hadoop
>          configuration.set("es.query",
> i got the error
> 10:58:27 INFO mapred.JobClient: Cleaning up the staging area
file:/tmp/hadoop-xxx/mapred/staging/xxx-1302405475/.staging/job_local_0001
> Exception in thread "main" java.lang.NullPointerException
>      at
org.elasticsearch.hadoop.rest.dto.Node.(Node.java:30)
>      at
org.elasticsearch.hadoop.rest.RestClient.getNodes(RestClient.java:139)
> Any idea?
> bestsregards
> philippe
> You received this message because you are subscribed to the Google
Groups "elasticsearch" group.
> To unsubscribe from this group and stop receiving emails from it,
send an email to
>elasticsearc...@googlegroups.com <javascript:>.
> To view this discussion on the web visit
https://groups.google.com/d/msgid/elasticsearch/2a52b4e7-3ecd-491b-8c6e-1d8d521260ef%40googlegroups.com
https://groups.google.com/d/msgid/elasticsearch/2a52b4e7-3ecd-491b-8c6e-1d8d521260ef%40googlegroups.com>.
> For more options, visithttps://groups.google.com/groups/opt_out <
https://groups.google.com/groups/opt_out>.
Costin
To unsubscribe from this group and stop receiving emails from it, send
an email to
https://groups.google.com/d/msgid/elasticsearch/1353d6b0-830e-4881-b10d-533639227a1c%40googlegroups.com.
Costin
