Quoting from the same docs again:
"EsOutputFormat expects a Map<Writable, Writable> representing a document
value that is converted interally into a JSON document and indexed in
Elasticsearch. Hadoop OutputFormat requires implementations to expect a key
and a value however, since for Elasticsearch only the document (that is the
value) is necessary, EsOutputFormat ignores the key."
As for MapWritable, it's Hadoop Map implementation - other than that, it's
just a map. It's not something es-hadoop provides but rather Hadoop. I
recommend spending some time getting familiar with Hadoop since es-hadoop
leverages many of its classes and concepts; after all it's a dedicated
'connector' to Elasticsearch for Hadoop.
P.S. In the future, please don't hijack old threads but rather start your
own - it's easier for everyone.
On Sat, Jul 26, 2014 at 12:19 AM, M_20 rastegar.83@gmail.com wrote:
Costin,
Thank you for your reply. I've read the official docs before. But it seems
I am missing something. So, I wanted to see a complete example to make sure
I am understanding ES-hadoop correctly.
For example, in the official docs, it talks about writing data to ES, and
this is the mapper
public void map(Object key, Object value, OutputCollector output,
Reporter reporter) throws IOException {
// create the MapWritable object
MapWritable doc = new MapWritable();
// write the result to the output collector
// one can pass whatever value to the key; EsOutputFormat ignores it
output.collect(NullWritable.get(), map);
Could you please tell me what's map in
Also, could you please tell me a little bit about "MapWritable doc"? How its format should be?
Regards
On Friday, July 25, 2014 3:25:21 PM UTC-5, Costin Leau wrote:
M_20, I've already replied to your initial query on where you can find
some example - the official docs:
Elasticsearch Platform — Find real-time answers at scale | Elastic
current/mapreduce.html
There's also google which points to other resources outside Elasticsearch.
On Fri, Jul 25, 2014 at 11:10 PM, M_20 raste...@gmail.com wrote:
Hi Chetana,
Could you please share with me a java sample code of Map/reduce on
Elastcisearch-Hadoop?
Regards
On Thursday, April 3, 2014 4:36:24 AM UTC-5, Chetana wrote:
I have downloaded elasticsearch-hadoop-1.2.0.jar from github and trying
to search. The code to search looks like
Configuration conf = new Configuration();
conf.set("es.nodes", "localhost");
conf.set("es.port", "9200");
conf.set("es.resource", "test_index/test_mapping");
conf.set("es.query", "{"query":{"term":{"test.
field1":"test"}}}");
Job job = Job.getInstance(conf);
job.setJobName(ESIndexContoller.class.getSimpleName());
job.setJarByClass(ESIndexContoller.class);
job.setInputFormatClass(EsInputFormat.class);
job.setOutputFormatClass(EsOutputFormat.class);
job.setOutputKeyClass(Text.class);
job.setOutputValueClass(MapWritable.class);
job.setSpeculativeExecution(false);
job.waitForCompletion(true);
I have hadoop 2.2 from hortonworks and ES 0.90.2. But when I run
'hadoop jar' command it throws 'IllegalStateException: Job in state DEFINE
instead of RUNNING'
I believe one needs to create custom Mapper and Reducer. If so, can
someone tell me how the code should look like inside map() and reduce()
Thanks,
You received this message because you are subscribed to the Google
Groups "elasticsearch" group.
To unsubscribe from this group and stop receiving emails from it, send
an email to elasticsearc...@googlegroups.com.
To view this discussion on the web visit https://groups.google.com/d/
msgid/elasticsearch/c54ca61b-26d8-4cad-91ee-80552ae13116%
40googlegroups.com
https://groups.google.com/d/msgid/elasticsearch/c54ca61b-26d8-4cad-91ee-80552ae13116%40googlegroups.com?utm_medium=email&utm_source=footer
email to elasticsearch+unsubscribe@googlegroups.com.
https://groups.google.com/d/msgid/elasticsearch/377ea0b8-ea98-4a38-9f83-a58849135667%40googlegroups.com
https://groups.google.com/d/msgid/elasticsearch/377ea0b8-ea98-4a38-9f83-a58849135667%40googlegroups.com?utm_medium=email&utm_source=footer
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CAJogdmd-4CZSPdrRxr%3DS_J7SgvUP7%2BusqeN0XMASh18CBpc2Mw%40mail.gmail.com.
