Hi
Could someone help with the query?
Here is couple of sample records (simplified) that are stored in elasticsearch
record#1
"some_field": true,
"products": {
"a": { "dt": "2018-08-28"},
"b": { "dt": "2018-08-29"},
"c": { "dt": "2018-08-27"},
"d": { "dt": "2018-08-20"},
record#2
"some_field": false,
"products": {
"a": { "dt": "2018-08-27"},
"d": { "dt": "2018-08-21"},
I am trying to write a query that would fetch the following result:
All records that have products "b" with dt in the range of 2018-08-20 and 2018-08-30 sorted by products.b.dt
I am running ES 2.4
Any help is appreciated.
I tried running the below query but it is throwing error. Basically, I wanted to run "range" only if the field exist
{ "query": { "bool": { "must": [ {"exists": { "field": "products.b"}}, {"range":{"products.b.dt": {"lt":" 2018-08-30", "gt": " 2018-08-20"} }} ] } } }
