Everything is in the title.
When I run the script from the gist : https://gist.github.com/1075067
Highlight is not returned.
Any idea ?
Regards,
ahb
Any idea ?
Regards,
ahb
Hi Alexandre,
Seems that you hit the same problem as before :
https://groups.google.com/group/elasticsearch/browse_thread/thread/8781e5b9bddd39e0/e9a9a0c509d2b807?#e9a9a0c509d2b807
Do you want me to test again the gist on my side ?
Did you start with a clean fresh new installation of ES ?
David.
On 14 mar, 16:50, Alexandre Heimburger alexheimbur...@gmail.com
wrote:
When I run the script from the gist :Test of attachments plugin · GitHub
Any idea ?
Regards,ahb
It's not really the same ptoblem because I run ES on a debian box, and I
get some result.
Just the highlight is missing.
Is it working on your side ?
On Wed, Mar 14, 2012 at 5:44 PM, David Pilato david@pilato.fr wrote:
Hi Alexandre,
Did you start with a clean fresh new installation of ES ?David.
wrote:Hi,
Any idea ?
Regards,ahb
blueKiwi is the innovation leader in Enterprise Social Software. Our
solutions enable enterprises worldwide to engage and interact with their
internal and external social networks in multiple business domains.
blueKiwi has been consistently recognized by Gartner Inc. as a visionary
provider since 2007.
I will try later (@home)
Keep in touch.
Le 14 mars 2012 à 18:20, Alexandre Heimburger ahb@bluekiwi-software.com a
écrit :
because I run ES on a debian box, and I get some result.
On Wed, Mar 14, 2012 at 5:44 PM, David Pilato < david@pilato.fr
mailto:david@pilato.fr > wrote:Seems that you hit the same problem as before :
https://groups.google.com/group/elasticsearch/browse_thread/thread/8781e5b9bddd39e0/e9a9a0c509d2b807?#e9a9a0c509d2b807Do you want me to test again the gist on my side ?
On 14 mar, 16:50, Alexandre Heimburger < alexheimbur...@gmail.com
mailto:alexheimbur...@gmail.com >
wrote:Hi,
When I run the script from the gist : Test of attachments plugin · GitHub
https://gist.github.com/1075067Highlight is not returned.
Any idea ?
Regards,ahb
VP Engineering
blueKiwi Software
tel : +33687880997
email : ahb@bluekiwi-software.com mailto:ahb@bluekiwi-software.com
adress : 93 rue Vieille du Temple, 75003 ParisblueKiwi is the innovation leader in Enterprise Social Software. Our
David Pilato
http://dev.david.pilato.fr/
Twitter : @dadoonet
Hi Alexandre,
Everything is working fine :
I get this answer from ES :
{"ok":true,"_shards":{"total":1,"successful":1,"failed":0}}{
"hits" : [ {
"_index" : "test",
"_type" : "attachment",
"_id" : "s_C9wgsCQRKteC4i_WbjjQ",
"_score" : 0.005872132,
"fields" : {
"file.title" : "ISL99201"
"highlight" : {
"file" : [ "\nMono <em>Amplifier</em>\nThe ISL99201 is a fully integrated high efficiency class-D \nmono <em>amplifier</em>. It is designed" ]
I used ES 0.19.0, elasticsearch-mapper-attachments-1.3.0, JDK 1.6.0_25 on Windows 7 32 bits.
HTH
David.
De : elasticsearch@googlegroups.com [mailto:elasticsearch@googlegroups.com] De la part de Alexandre Heimburger
Envoyé : mercredi 14 mars 2012 18:20
À : elasticsearch@googlegroups.com
Objet : Re: Highlight does not work when searching on attachment with ES 0.19
It's not really the same ptoblem because I run ES on a debian box, and I get some result.
Hi Alexandre,
David.
wrote:
Any idea ?
Regards,ahb
VP Engineering
blueKiwi Software
tel : +33687880997
blueKiwi is the innovation leader in Enterprise Social Software. Our solutions enable enterprises worldwide to engage and interact with their internal and external social networks in multiple business domains. blueKiwi has been consistently recognized by Gartner Inc. as a visionary provider since 2007.
Ok. The thing was related to my default analyzer which was the keyword one.
Using a standard analyzer correct my issue.
Thanks guys
On Wed, Mar 14, 2012 at 10:34 PM, David Pilato david@pilato.fr wrote:
Hi Alexandre,****
Everything is working fine :****
I get this answer from ES :****
{"ok":true,"_shards":{"total":1,"successful":1,"failed":0}}{****
"hits" : [ {**** "_index" : "test",**** "_type" : "attachment",**** "_id" : "s_C9wgsCQRKteC4i_WbjjQ",**** "_score" : 0.005872132,**** "fields" : {**** "file.title" : "ISL99201"**** },**** "highlight" : {**** "file" : [ "\nMono <em>Amplifier</em>\nThe ISL99201 is a fullyintegrated high efficiency class-D \nmono amplifier. It is
designed" ]****}**** } ]****}****
Windows 7 32 bits.****
HTH****
David.****
ES 0.19****
get some result.****
Just the highlight is missing.****
Is it working on your side ?****
On Wed, Mar 14, 2012 at 5:44 PM, David Pilato david@pilato.fr wrote:****
Hi Alexandre,
wrote:****Hi,
Any idea ?
Regards,ahb****
VP Engineering
blueKiwi Software
tel : +33687880997
adress : 93 rue Vieille du Temple, 75003 Paris****
provider since 2007.****
