How speed index
My server have 48gb ram and 500GB free space, digital ocean server very strong cpu
how to configure yaml to speed index, please someone give me an example.
These docs contain some good guidance. Indexing is often bound by disk I/O so make sure you have SSD level performance for optimal indexing performance.
# ======================== Elasticsearch Configuration =========================
    # NOTE: Elasticsearch comes with reasonable defaults for most settings.
    #       Before you set out to tweak and tune the configuration, make sure you
    #       understand what are you trying to accomplish and the consequences.
    # The primary way of configuring a node is via this file. This template lists
    # the most important settings you may want to configure for a production cluster.
    # Please consult the documentation for further information on configuration options:
    # https://www.elastic.co/guide/en/elasticsearch/reference/index.html
    # ---------------------------------- Cluster -----------------------------------
    # Use a descriptive name for your cluster:
    #cluster.name: my-application
    # ------------------------------------ Node ------------------------------------
    # Use a descriptive name for the node:
    #node.name: node-1
    # Add custom attributes to the node:
    #node.attr.rack: r1
    # ----------------------------------- Paths ------------------------------------
    # Path to directory where to store the data (separate multiple locations by comma):
    path.data: /var/lib/elasticsearch
    # Path to log files:
    path.logs: /var/log/elasticsearch
    # ----------------------------------- Memory -----------------------------------
    # Lock the memory on startup:
    #bootstrap.memory_lock: true
    # Make sure that the heap size is set to about half the memory available
    # on the system and that the owner of the process is allowed to use this
    # limit.
    # Elasticsearch performs poorly when the system is swapping the memory.
    # ---------------------------------- Network -----------------------------------
    # Set the bind address to a specific IP (IPv4 or IPv6):
    #network.host: 192.168.0.1
    # Set a custom port for HTTP:
    #http.port: 9200
    # For more information, consult the network module documentation.
    # --------------------------------- Discovery ----------------------------------
    # Pass an initial list of hosts to perform discovery when this node is started:
    # The default list of hosts is ["127.0.0.1", "[::1]"]
    #discovery.seed_hosts: ["host1", "host2"]
    discovery.seed_hosts: ["host-1","host-2","host-3","host-4","host-5","host-6","host-7","host-8","host-9","host-10","host-11","host-12"]
    # Bootstrap the cluster using an initial set of master-eligible nodes:
    cluster.initial_master_nodes: ["node-1","node-2","node-3","node-4","node-5","node-6","node-7","node-8","node-9","node-10","node-11","noe-12","node-13","node-14","node-15","node-16","node-17","node-18","node-19","node-20","node-21","node-22","node-23","node-24","node-25","node-26","node-27","node-28","node-29","node-30","node-31","node-32","node-33","node-34","node-35","node-36"]
    # For more information, consult the discovery and cluster formation module documentation.
    # ---------------------------------- Gateway -----------------------------------
    # Block initial recovery after a full cluster restart until N nodes are started:
    gateway.recover_after_nodes: 9
    # For more information, consult the gateway module documentation.
    # ---------------------------------- Various -----------------------------------
    # Require explicit names when deleting indices:
    # action.destructive_requires_name: true
    #index.refresh_interval: "300ms"
    index.refresh_interval: 30s
give me some tips to fix and speed index please, thanks a lot
Did you look at the docs I linked to? If you are having issues with indexing performance, have you determined what the bottleneck is, e.g. disk utilization?
