How to create a watcher script to match one field with other field in same document
Hi ,
Can anyone please help me on this scenario to create an alert
I am having a log events like the following
<#> 20200806 17:04:23.261 280018000 EV.WRN [ MVINB-LSL2.T1G1_WEBSVR1 main.main TSP1.T1G1_WEBSVR1 ] Failed to load TermRecord for TermID=f6y4jkm
<#> 20200806 17:04:23.261 280018000 EV.INF [ MVINB-LSL2.T1G1_WEBSVR1 main.main TSP1.T1G1_WEBSVR1 ] Failed to load TermRecord for TermID=7yhe73v
<#> 20200806 17:04:23.261 280018000 EV.FNE [ MVINB-LSL2.T1G1_WEBSVR1 main.main TSP1.T1G1_WEBSVR1 ] Failed to load TermRecord for TermID=j6ljudn
here EV.WRN is the "event_type" and "Failed to load TermRecord for TermID=f6y4jkm" is the log_message.
i want to create an alert if get the the same "event_type" with the same "log_message"
with the same term id. Is there a way to generate and alert based upon this scenario. the following is my current watcher script.
"trigger": {
"schedule": {
"interval": "10s"
"input": {
"search": {
"request": {
"indices": [
"testingalert*"
"rest_total_hits_as_int": true,
"body": {
"size": 0,
"bool": {
"must": {
"query_string": {
"query": "Failed to load TermRecord for TermID=/a-zA-Z0-9_.-/"
"filter": {
"range": {
"@timestamp": {
"gte": "{{ctx.trigger.scheduled_time}}||-5m",
"lte": "{{ctx.trigger.scheduled_time}}",
"format": "strict_date_optional_time||epoch_millis"
"aggs": {
"log_message": {
"terms": {
"field": "log_message.keyword",
"size": 10
"aggs": {
"id": {
"terms": {
"field": "term_id.keyword",
"size": 10
"condition": {
"script": {
"source": "ArrayList arr = ctx.payload.aggregations.log_message.buckets; for (int i = 0; i < arr.length; i++) { if (arr[i].doc_count > params.threshold) { return true; } } return false;",
"lang": "painless",
"params": {
"threshold": 2
"actions": {
"send_email": {
"email": {
"profile": "standard",
"to": [
"anonymousbeendetected@gmail.com"
"subject": "Watcher Notification",
"body": {
"text": "Watch [{{ctx.metadata.name}}] The 'Terminal ID' alert has occured more than 5 times in 5 minutes interval of time"
"transform": {
"script": {
"source": "HashMap result = new HashMap(); ArrayList arr = ctx.payload.aggregations.log_message.buckets; ArrayList filteredHits = new ArrayList(); for (int i = 0; i < arr.length; i++) { HashMap filteredHit = new HashMap(); filteredHit.key = arr[i].key; filteredHit.value = arr[i].doc_count; if (filteredHit.value > params.threshold) { filteredHits.add(filteredHit); } } result.results = filteredHits; return result;",
"lang": "painless",
"params": {
"threshold": 2
