How to create an index_2 containing Index_1's aggregations results as fields?
How to create an index_2 containing Index_1's aggregations results as fields ?
Is it possible to use a command like this on kibana dev tools ?
PUT /index_2/doc_aggs_results_of_index1
field_aggs1: ...
field_aggs2: ...
For example:
Index_1 contains:
doc1:
city: New-York
date: 01-05-2015
doc2:
city: Los Angeles
date: 22-07-2018
doc3:
city: Sidney
date: 12-10-2017
doc4:
city: Paris
date: 17-02-2018
And I'd like to create index that aggregates or queries on index_1 to make index_2 :
Index_2 contains:
doc1:
cities: [
city: New-York,
date: 01-05-2015
city: Sidney,
date: 12-10-2017
doc2:
cities: [
city: Los Angeles,
date: 22-07-2018
city: Paris,
date: 17-02-2018
Hi, maybe dataframe transforms can help you with this: https://www.elastic.co/guide/en/elasticsearch/reference/7.6/ecommerce-transforms.html
It could have worked but unfortunatelly it seems that it only takes metric aggregations
Ah, I see. In this case you probably have to solve it outside of Elasticsearch- writing a script which executes the aggregation and feeds back the result into a separate index.
Maybe someone else can come up with a better solution. As this isn’t Kibana specific, it probably makes sense to repost this question in the Elasticsearch category.
This is not correct, transform supports other aggs as well, with scripted_metric - despite metric in the name - allows custom code which opens a lot of use cases.
We are expanding the list of supported aggs with every release. Which aggregations do you need?
I need terms aggregation but the dev tools manager answers to me:
"error": {
"root_cause": [
"type": "status_exception",
"reason": "Unsupported aggregation type [terms]"
thanks, we already have an enhancement request for terms.
In case its a small and known set of terms you can use a filter aggregation in the upcoming 7.7, see this example.
As already pointed out, with scripted_metric you could create a HashSet to map/reduce a terms frequency list.
I can not say when terms support in pivot will be available, but as this is a top ask: hopefully soon.
Filter doesn't adress my issue because it works by mentionning a specific field value, but I need to gather docs by field name.
For bucketing you use group_by, which supports grouping by term. For the collapsing part you can use a scripted_metric.
Here is an example configuration. The only thing missing according to your start post is dropping the field name.
POST _transform/_preview
  "source": {
    "index": "index-1"
  "dest" : {
    "index" : "index-2"
  "pivot": {
    "group_by": {
      "clientip": { "terms": { "field": "name" } }
  "aggregations": {
    "all_docs": {
      "scripted_metric": {
        "init_script": "state.docs = []",
        "map_script": "state.docs.add(new HashMap(params['_source']))",
        "combine_script": "return state.docs",
        "reduce_script": "def docs = []; for (s in states) {for (d in s) { docs.add(d);}}return docs"
