I'm install elastic search 0.16.2 on Debian Linux.I want to connect
elastic server which is install Debian machine. previously I install
elastic server in my machine.for creating node i used following code:
If you want to connect to a remote node / cluster, then you should not use
"local". What it means is that a cluster will be formed from the nodes
started within the same JVM, but thats it.
I'm install Elasticsearch 0.16.2 on Debian Linux.I want to connect
logo are trademarks of the
Apache Software Foundation
