How to cross check weather my beats are running or not
Hi team,
In an environment of monitoring 100 server using packetbeat, How do i know that all 100 beats are running fine and i data is streaming ?
Is there any configuration to be done at beats side ?
Ramya
Have you seen https://www.elastic.co/guide/en/beats/packetbeat/current/monitoring.html?
@warkolm ,Thank you.
Yeah,I have gone through this but , in production we are not using X-pack.
If we don't use x-pack what are the ways to monitor Beats ?
You should! It's free and works really well :slight_smile:
If you aren't using that, then you maybe you can use metricbeat to monitor the packetbeat service.
Thanks for your suggestions :slight_smile:
Could you please elaborate how Metricbeat can monitor packetbeat.and if we use metricbeat/packetbeat/filebeat/heartbeat what are the ways of monitoring them.
https://www.elastic.co/guide/en/beats/metricbeat/current/metricbeat-metricset-system-process.html has info on process monitoring.
Thank you for your time :slight_smile:
