In my application, I have a map of <term, weight> pairs that I would like
to index into the same field, say "f", where the term should be indexed "as
is", ie, un-analyzed, and the weight should be indexed as the payload for
that term. I only need payloads for that field, and not term vectors. Each
document would have a different map of <term, weight> pairs to be indexed
as term and payload into the field "F". I am using ES 1.4, with the Java
API for both indexing and searching.
I had been doing this (indexing and scoring) directly with Lucene thus far.
However, after reading the ElasticSearch documentation, I could not find
any API, or even an approach, for how to achieve payload indexing in
ElasticSearch
I did find some documentation on how to use scripting for extracting and
using the payloads for scoring; this part would work, but I would prefer a
Java API approach, because it would avoid the scripting performance hit.
Any help on this, especially the indexing part, would be appreciated.
-devarajaswami
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/e047c379-a23e-490f-a1e6-31d28dfa8c06%40googlegroups.com.
