How to monitor cause of deletion of documents in index?
Dears,
Is there any way to monitor process of deletion of documents from index?
I'm asking about it because of from few days I observed this odd behavior. Similar situation I had when doc id was the same for few documents. I wonder what the cause is this time. Any idea?
Best Regards,
Dan
Elasticsearch doesn't delete docs, unless you are on an old version and using TTL.
Otherwise something is telling Elasticsearch to delete them.
Do you have access control on your cluster?
@warkolm
Yes, I have access control on my cluster.
In my infrastructure few filebeats send applications logs to ELK, users have access to Kibana to see the logs with read only rights.
