How to pass variable to the body section of script in webhook watcher?
I have the following webhook watcher which creates OTRS ticket when there is a term "Error" in document. However right now the ticket body declared in script is a fixed string for now ( This is only a test). How to pass the message body to the script so that when the ticket is created it desplays the actual message of the input?
  "trigger": {
    "schedule": {
      "interval": "1m"
  "input": {
    "search": {
      "request": {
        "indices": [
        "rest_total_hits_as_int": true,
        "body": {
            "bool": {
              "must": [
                  "query_string": {
                    "query": "Error"
                  "range": {
                    "@timestamp": {
                      "gte": "now-1m"
  "condition": {
    "compare": {
      "ctx.payload.hits.total": {
        "gte": 1
  "actions": {
    "create_otrs": {
      "transform": {
        "script": {
          "source": "return ['Ticket':['Queue':'Engineering Team','Priority':'P3','CustomerUser':'root','Title':'RESTCreateTest','State':'new','Type':'Incident'],'Article':['ContentType':'text/plain;charset=utf8','Subject':'RestCreateTest','Body':'This is only a test']]",
          "lang": "painless"
      "webhook": {
        "scheme": "http",
        "host": "myotrs.com",
        "port": 80,
        "method": "post",
        "path": "/otrs/GenericTicketConnectorREST/User=<User>&Pass=<Password>",
        "headers": {},
        "body": "{{#toJson}}ctx.payload{{/toJson}}"
One of the example hit is -
"_index": ".ds-logs-elastic_agent.filebeat-default",
                "_source": {
                  "input_source": "https://ser.example.com:80/export",
                  "agent": {
                    "name": "syslog01",
                    "id": "5836558b-b17d-445e",
                    "type": "filebeat",
                    "ephemeral_id": "36bdfeca-3c60",
                    "version": "8.3.3"
                  "service.name": "filebeat",
                  "log": {
                    "file": {
                      "path": "/opt/Elastic/Agent/data/elastic-agent-0ffbed/logs/default/filebeat-20230127-12.ndjson"
                    "offset": 248078415
                  "elastic_agent": {
                    "id": "5836558b-b17d",
                    "version": "8.3.3",
                    "snapshot": false
                  "message": """Error while processing http request: failed to execute rf.collectResponse: failed to execute http client.Do: failed to execute http client.Do: Post "https://ser.example.com:80/export": POST https://ser.example.com:80/export giving up after 6 attempts""",
                  "log.logger": "input.httpjson-cursor",
                  "input": {
                    "type": "filestream"
                  "log.origin": {
                    "file.line": 128,
                    "file.name": "httpjson/input.go"
                  "@timestamp": "2023-01-27T14:44:42.790Z",
                  "ecs": {
                    "version": "8.0.0"
                  "data_stream": {
                    "namespace": "default",
                    "type": "logs",
                    "dataset": "elastic_agent.filebeat"
                  "host": {
                    "hostname": "syslog01",
                    "os": {
                      "kernel": "3.10.25-gentoo",
                      "name": "Gentoo",
                      "type": "linux",
                      "family": "",
                      "version": "",
                      "platform": "gentoo"
                    "containerized": false,
                  "log.level": "error",
                  "input_url": "https://ser.example.com:8089/export",
                  "id": "httpjson-system.security-ba2ec41b-457b-442a",
                  "event": {
                    "ingested": "2023-01-27T14:44:58Z",
                "_id": "pCWw84UB8FDLddfs",
                "_score": 2.2840834
I want to pass the "message" field of the document into the script in 'Body':'This is only a test'
Just make your transform script something like:
        "transform": {
          "script": """return ['Ticket':['Queue':'EngineeringTeam','Priority':'P3','CustomerUser':'root@localhost','Title':'RESTCreateTest','State':'new','Type':'Incident'],'Article':['ContentType':'text/plain;charset=utf8','Subject':'RestCreateTest','Body':ctx.payload.hits.hits.0._source.message]]"""
But, of course, this is the message field for only the first (out of possibly many) documents that matched the input query. If you're okay with that....
Thank you so much. Its working fine.
