ILM: index not showing in Cold phase and Delete phase
I'm using Winlogbeat and i've defined a lifecycle with the following phases: Hot, Warm, Cold and Delete. In Index Management i have indices only for Hot and Warm phases.
Could someone tell me what is wrong?
Any help will be appreciated.
Thank you!
Here is my ILM Policy
PUT _ilm/policy/winlogbeat
"policy": {
"phases": {
"hot": {
"min_age": "0ms",
"actions": {
"rollover": {
"max_age": "1d",
"max_size": "3gb"
"set_priority": {
"priority": 100
"warm": {
"actions": {
"allocate": {
"include": {},
"exclude": {},
"require": {
"box_type": "warm"
"set_priority": {
"priority": 50
"delete": {
"min_age": "150d",
"actions": {
"delete": {
"delete_searchable_snapshot": true
The policy you defined only has hot, warm and delete. There's no cold that I can see.
Also that's pretty small. You might want to look at increasing the age and size to something a little larger to make sure you are using your cluster resources effectively.
Thanks. I added the missing node and It works fine now.
