I'm currently running ES 1.7.1 although the docs for this haven't changed so I'm not sure that's relevant.
The docs for these settings give a fairly decent explanation of these settings but it's a bit unclear why max_index_buffer_size would be required if index_buffer_size has been set.
indices.memory.index_buffer_size
Accepts either a percentage or a byte size value. It defaults to 10%, meaning that 10% of the total heap allocated to a node will be used as the indexing buffer size shared across all shards.
indices.memory.min_index_buffer_size
If the index_buffer_size is specified as a percentage, then this setting can be used to specify an absolute minimum. Defaults to 48mb.
indices.memory.max_index_buffer_size
If the index_buffer_size is specified as a percentage, then this setting can be used to specify an absolute maximum. Defaults to unbounded.
Example:
ES heap size is 10g
index_buffer_size is set to 10%
I'd assume that implies ES will share 1g of heap among the shards currently indexing.
I'd also assume that implies a max of 10% (1g) but then why would max_index_buffer_size exist.
Questions:
Does "shared across all shards" imply just shards from indices currently doing indexing or does this imply all shards from all open indices share this memory?
How does index_buffer_size truly differ from max_index_buffer_size?
