Hello, I'm using ElasticSearch 0.20.6 and trying to index the first element
in an array as a multi_field type. I need to query for the first item in
an array, and this is the only way I could come up with:
I want to query places.places_first:mall and get one hit. Currently I'm
getting two, which is why I think something must be wrong with my pattern.
Also, is there a better way to query or index the data for my purposes?
Hello, I'm using Elasticsearch 0.20.6 and trying to index the first
element in an array as a multi_field type. I need to query for the first
item in an array, and this is the only way I could come up with:
Yes, and the analyze API gives me the single token I expect for this regex
(the first item in the array). Is there something I'm doing wrong in how
I'm indexing the array as a multi_field?
On Wednesday, May 8, 2013 11:00:11 AM UTC-4, Ivan Brusic wrote:
Have you tried using the analysis API to test your analyzer?
"elasticsearch" group.
Looking at your data, the places field is multi-valued, so the analyzer
will be applied to each value of the field, which means it will find the
first word of every value, or in your case, every value.
Your array would need to be represented as a single string for your
tokenizer to work. Lucene has a LimitTokenCountFilter, but it is not
exposed in Elasticsearch. You can create a plugin to support that filter,
or open an issue and have the ES team expose the filter.
Groups "elasticsearch" group.
an email to elasticsearc...@**googlegroups.com.
Cheers,
Ivan
regex (the first item in the array). Is there something I'm doing wrong in
how I'm indexing the array as a multi_field?
I'm getting two, which is why I think something must be wrong with my
pattern. Also, is there a better way to query or index the data for my
purposes?
Adding support for an existing Lucene filter is almost trivial. I will
submit a pull request if I find the time (not today!). If you don't want to
wait for a fix to be released, a plugin is not difficult, but it requires a
lot of boilerplate code. You can work off any of the existing analysis
plugins.
purposes?
an email to elasticsearc...@**googlegroups.**com.
Good to hear it is fairly straightforward! I have an existing plugin I've
built to power the specific search functionality I need. I'll try adding
this to my plugin. Thanks again for your help!
plugins.
Ivan
purposes?
send an email to elasticsearc...@**googlegroups.**com.
logo are trademarks of the
Apache Software Foundation
