I had a template named "30days_cleanup_template" set for a particular index which was part of the ILM policy named "cleanup-history". Template was set as follows:
PUT _template/30days_cleanup_template
"index_patterns": [ "asi-*"],
"settings": {
"number_of_shards": 1,
"number_of_replicas": 1,
"index.lifecycle.name": "cleanup-history",
"index.lifecycle.rollover_alias": "cgbuat-alias"
"clean-up-history" looks like below"
PUT _ilm/policy/cleanup-history
"policy": {
"phases": {
"hot": {
"actions": {}
"delete": {
"min_age": "30d",
"actions": {
"delete": {}
This set up was working fine with 30 days retention in effect.
Lately there was a requirement to introduce _index_template to set "highlight.max_analyzed_offset" to a higher number on the same index. I went ahead and created the index_template as follows mentioning no priority:
PUT /_index_template/template_10844
"index_patterns" : ["asi-*"],
"template": {
"settings" : {
"highlight.max_analyzed_offset" : 3000000
After the above was set now I see that the ILM policy is not effective on the index any more as seen by using :
GET asi-2023.06.03/_settings
It only shows the output as follows and does not show the index lifecycle settings any more as if that was overwritten:
"asi-2023.06.03" : {
"settings" : {
"index" : {
"highlight" : {
"max_analyzed_offset" : "3000000"
"routing" : {
"allocation" : {
"include" : {
"_tier_preference" : "data_content"
"number_of_shards" : "1",
"provided_name" : "csi-170844-2023.06.03",
"creation_date" : "1685750401230",
"number_of_replicas" : "1",
"uuid" : "rj5VA3KJRmm7-edU79SHOA",
"version" : {
"created" : "7130299"
Please guide as to how can I avoid ILM policy getting overwritten.
