Index naming problem
I'm trying to insert documents into an Elasticsearch index from a filebeat, through Logstash processing.
My Logstash config looks like this:
beats {
port => 5044
hosts => ["localhost:9200"]
index => ["logstash-%{+YYYY.MM.dd}"]
The problem I have is that Elasticsearch then creates the index named:
logstash-0018.01.16
And I can't find any data in this index.
Does anyone know what's wrong with this config?
Question moved to #logstash.
Please format your code using </> icon as explained in this guide. It will make your post more readable.
Or use markdown style like:
CODE
