I have an ingest node that contains:
- date:
field: "event.start"
formats:
- "ISO8601"
if: "ctx.event?.start != null && ctx.agent.type == 'packetbeat'"
ignore_failure: true
The elasticsearch runs behind logstash and packetbeat communicates with logstash.
In my machine where packetbeat runs, I start a process that creates hundreds of connections per second, thus hundreds of events to be logged. In the packetbeat logs, I get the following error multiple times:
May 16 21:08:56 my-machine packetbeat[908]: 2020-05-16T21:08:56.155Z ERROR [logstash] logstash/async.go:279 Failed to publish events caused by: write tcp 10.0.23.181:45182->35.206.159.154:5044: write: connection reset by peer
May 16 21:08:57 my-machine packetbeat[908]: 2020-05-16T21:08:57.624Z ERROR [publisher_pipeline_output] pipeline/output.go:127 Failed to publish events: write tcp 10.0.23.181:45182->35.206.159.154:5044: write: connection reset by peer
In the elasticsearch logs, I see:
"Caused by: org.elasticsearch.common.breaker.CircuitBreakingException: [script] Too many dynamic script compilations within, max: [75/5m]; please use indexed, or scripts with parameters instead; this limit can be changed by the [script.max_compilations_rate] setting",
How can I use a stored script with the if conditional of the processor? And, in general, how am I supposed to solve this issue?
