I am using .Nest version 7.x and I am trying to post information to a remote elasticsearch log bridge. Using the following code:
                var object_test= new Dummy_Object{
                Dummy_String = "dummy_data",
                Dummy_Int = 3
              ConnectionSettings settings = new ConnectionSettings(new Uri("https://base_url.com/v2/applications"))
        .BasicAuthentication("user_name", "password")
        .EnableDebugMode();
                ElasticClient client = new ElasticClient(settings);
                IndexResponse indexResponse = client.Index(new IndexRequest<Dummy_Object>(object_test, "index_IAm_Posting_To"));
                Console.WriteLine(indexResponse.DebugInformation);
Yet it does not work, I am not very experienced with using .NEST but have tested this index already and posted data to using this HTTP request:
https://base_url/v2/applications/index/log
Which submitted successfully, i've tested the uri without v2/application but it did not work. Here is the output I am looking at:
Invalid NEST response built from a unsuccessful (404) low level call on POST: /v2/applications/index/_doc?pretty=true&error_trace=true
Audit trail of this API call:
- [1] BadResponse: Node: https://base_url/v2/applications/ Took: 00:00:01.7605315
OriginalException: Elasticsearch.Net.ElasticsearchClientException: Request failed to execute. Call: Status code 404 from: POST /v2/applications/index/_doc?pretty=true&error_trace=true
Request:
{"Dummy_String":"dummy_data","Dummy_Int:"3"}
Response:
ErrorCannot POST /v2/applications/index/_doc
TCP states:
Established: 318
TimeWait: 14
CloseWait: 17
ThreadPool statistics:
Worker:
Busy: 0
Free: 32767
Min: 12
Max: 32767
IOCP:
Busy: 0
Free: 1000
Min: 12
Max: 1000
