Invalid NEST response built from a successful (404) low level call
Using indexMany mapping, and getting this error:
Invalid NEST response built from a successful (404) low level call on POST: /cat/_bulk
Invalid Bulk items:
Audit trail of this API call:
Request:
{"index":{"_id":"1"}}
{"id":1,"productCount":0,"name"[{"languageId":0,"text":"Computers"}],"analyzedName":[{"languageId":0,"text":"Computers"}],"seName":[{"languageId":0,"text":"computers"},{"languageId":1,"text":"computers"}]}
Response:
{"statusCode":404,"error":"Not Found","message":"Not Found"}
Mapping of cat index:
PUT cat/_mapping
"properties" : {
"id" : {
"type" : "long"
"analyzedName" : {
"type" : "nested",
"properties" : {
"languageId" : {
"type" : "integer"
"text" : {
"type" : "text",
"analyzer" : "bigram_combiner"
"name" : {
"type" : "nested",
"properties" : {
"languageId" : {
"type" : "integer"
"text" : {
"type" : "text"
"seName" : {
"type" : "nested",
"properties" : {
"languageId" : {
"type" : "integer"
"text" : {
"type" : "text"
"productCount" : {
"type" : "integer"
The response
looks familiarly like the one in Why does the HTTP authentication with Elasticsearch fail in Rust?.
This doesn't look like a response from Elasticsearch. The Url in the audit trail of http://localhost:5601/ is the default one for Kibana. Are you sending the request to Kibana instead of sending it to Elasticsearch? The default Url for Elasticsearch running locally is http://localhost:9200/
yes but, when i run the server it says that the server is running at 5601
anyway it fixed it. Thank you.
Kibana is running on localhost:5601, but the Elasticsearch clients, like NEST, make calls to Elasticsearch APIs
