Invalid NEST response built from a unsuccessful () low level call on PUT:
hi ,
I've used multi-instance elastic but when I use the hostname I get this error
Elasticsearch.Net.ElasticsearchClientException: Failed to ping the specified node.. Call: unknown resource
But using IP in output elasticsearch - logstash working fine
I used this for multi instance->StaticConnectionPool
Welcome to our community! :smiley:
I don't know the NEST client, but if you could add the code you are using and the full error it will help those that know help you find a resolution
