Как добавить "is_write_index": true в index template?
Если добавляю эту опцию к template который указываю в template_name в output { elasticsearch { template_name => "haproxy" } }, то она просто пропадает.
И в GET /_template/haproxy вижу:
"aliases" : {
"haproxy" : { }
Хотя в PUT /_template/haproxy четко указал:
"aliases" : {
"haproxy" : {
Как добавить эту опцию чтобы ILM не ругался на
illegal_argument_exception: source alias [haproxy] does not point to a write index
Do any aliases exist?
GET _cat/indices/haproxy*
I think you assigned the alias to the template, the alias needs to be assigned to the index with one having "is_write_index": true.
Через template не получится (я открыл https://github.com/elastic/elasticsearch/issues/52152), надо либо индекс либо алиас вручную создавать.
Но индексы каждый час создает logstash, назначать alias там возможности нет, есть только такой функционал:
ilm_rollover_alias => "custom"
ilm_pattern => "000001"
ilm_policy => "custom_policy"
У меня конфигурация такая:
id => "HAP Out"
hosts =>
user => ""
password => ""
index => "haproxy-%{+YYYY.MM.dd-HH}"
Что тогда в ilm_pattern прописать?
No aliases. How can I assign alias to index created hourly by logstash?
ILM rollover phase will move the is_write_alias to the new index at rollover. To get started, the first index needs to exist and have is_write_alias: true. Use a POST like this to update the latest haproxy index with the is_write_alias.
POST /_aliases
    "actions" : [
            "add" : {
                 "index" : "haproxy-000001",
                 "alias" : "haproxy",
                 "is_write_index" : true
If you don't have the initial ILM style index, you can create it as in the doc example
PUT datastream-000001
  "aliases": {
    "datastream": {
It's a frequent confusion getting ILM working for the first time in more complex configurations, but once it works, you will see that there are many different ways to configure ILM.
Logstash creates index every hour, I posted my output section above, what exactly should I do?
To output all data in one manually created index? I don't get it, sorry.
After creating the "haproxy-000001" index that has the is_write_alias: true, the output below should work. You will point to the alias, the index where is_write_alias is true will get the output. Only one is allowed and it will move to haproxy-000002 at rollover.
    id => "HAP Out"
    hosts =>
    user => ""
    password => ""
    index => "haproxy"
    ilm_enabled => true
