Issue about index lifecycle management
I am very new to ELK. I have setup kibana, elasticsearch, logstash and filebeat. Data can be received successfully and shown in kibana but I have problem with index lifecycle management. There is always error like this: illegal_argument_exception: index.lifecycle.rollover_alias [filebeat-7.6.1] does not point to index [filebeat-7.6.1-2020.04.15]
I have tried to create new index myself: filebeat-7.6.1-2020.04.15-000001 and set it as write index and apply ilm but no data go into this index. The data goes into the old index. But I find out the index i create can roll up and delete itself as i want(so filebeat-7.6.1-2020.04.15-000001 is no longer exist and the existing one is filebeat-7.6.1-2020.04.15-000006 ). I really not sure what I miss. What i want to accomplish to build an index that can roll up each day, data goes into that index and it will be deleted itself a few days later.
Here is the setting of original index
  "filebeat-7.6.1-2020.04.15" : {
    "settings" : {
      "index" : {
        "lifecycle" : {
          "name" : "filebeat",
          "rollover_alias" : "filebeat-7.6.1"
        "mapping" : {
          "total_fields" : {
            "limit" : "10000"
        "refresh_interval" : "5s",
        "number_of_shards" : "1",
        "provided_name" : "filebeat-7.6.1-2020.04.15",
        "query" : {
          "default_field" : [
        "creation_date" : "1586943253337",
        "number_of_replicas" : "1",
        "uuid" : "nGw2BjyqTC6HODLTRRka1w",
        "version" : {
          "created" : "7060199"
Here is the setting of alias for the original index
    "aliases" : { }
Here is the ilm setting for the original index
  "indices" : {
      "index" : "filebeat-7.6.1-2020.04.15",
      "managed" : true,
      "policy" : "filebeat",
      "lifecycle_date_millis" : 1586943253337,
      "age" : "5.91d",
      "phase" : "hot",
      "phase_time_millis" : 1587453505620,
      "action" : "rollover",
      "action_time_millis" : 1586943259018,
      "step" : "ERROR",
      "step_time_millis" : 1587454105616,
      "failed_step" : "check-rollover-ready",
      "is_auto_retryable_error" : true,
      "failed_step_retry_count" : 8963,
      "step_info" : {
        "type" : "illegal_argument_exception",
        "reason" : "index.lifecycle.rollover_alias [filebeat-7.6.1] does not point to index [filebeat-7.6.1-2020.04.15]",
        "stack_trace" : """java.lang.IllegalArgumentException: index.lifecycle.rollover_alias [filebeat-7.6.1] does not point to index [filebeat-7.6.1-2020.04.15]
	at org.elasticsearch.xpack.core.ilm.WaitForRolloverReadyStep.evaluateCondition(WaitForRolloverReadyStep.java:104)
	at org.elasticsearch.xpack.ilm.IndexLifecycleRunner.runPeriodicStep(IndexLifecycleRunner.java:152)
	at org.elasticsearch.xpack.ilm.IndexLifecycleService.triggerPolicies(IndexLifecycleService.java:328)
	at org.elasticsearch.xpack.ilm.IndexLifecycleService.triggered(IndexLifecycleService.java:266)
	at org.elasticsearch.xpack.core.scheduler.SchedulerEngine.notifyListeners(SchedulerEngine.java:183)
	at org.elasticsearch.xpack.core.scheduler.SchedulerEngine$ActiveSchedule.run(SchedulerEngine.java:211)
	at java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
	at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
	at java.base/java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
	at java.base/java.lang.Thread.run(Thread.java:830)
      "phase_execution" : {
        "phase_definition" : {
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_size" : "50gb",
              "max_age" : "1d"
        "version" : 7,
        "modified_date_in_millis" : 1586955921457
Here is the setting of the index I create:
  "filebeat-7.6.1-2020.04.15-000006" : {
    "settings" : {
      "index" : {
        "lifecycle" : {
        "mapping" : {
          "total_fields" : {
            "limit" : "10000"
        "provided_name" : "filebeat-7.6.1-2020.04.15-000006",
        "query" : {
          "default_field" : [
        "creation_date" : "1587390505607",
        "uuid" : "3sHTKpJjQ3OkW9IOxM1t5A",
        "version" : {
The alias setting for the index i create
    "aliases" : {
      "filebeat-7.6.1" : {
        "is_write_index" : true
the ilm setting for the index i create
  "indices" : {
      "index" : "filebeat-7.6.1-2020.04.15-000006",
      "managed" : true,
      "lifecycle_date_millis" : 1587390505607,
      "age" : "17.82h",
      "phase" : "hot",
      "phase_time_millis" : 1587390506056,
      "action_time_millis" : 1587391106375,
      "step" : "check-rollover-ready",
      "step_time_millis" : 1587391106375,
          "min_age" : "0ms",
          "actions" : {
            "rollover" : {
              "max_age" : "1d"
        "version" : 7,
Please reformat your code/logs/config using the </> button, or markdown style back ticks. It helps to make things easy to read which helps us help you :slight_smile:
Sure....Please help.
anyone can help?
