I am setting a EFK stack in a Kubernetes single host cluster. Everything works perfectly with http. However, when I enable TLS in Fluent-bit ConfigMap, I experience the following error:
[2024/07/04 16:51:57] [error] [tls] error: unexpected EOF
[2024/07/04 16:51:57] [ warn] [engine] failed to flush chunk '1-1720111186.704158600.flb', retry in 84 seconds: task_id=47, input=tail.0 > output=es.0 (out_id=0)
[2024/07/04 16:51:58] [error] [tls] error: unexpected EOF
[2024/07/04 16:51:58] [ warn] [engine] failed to flush chunk '1-1720111346.704169721.flb', retry in 612 seconds: task_id=208, input=tail.0 > output=es.0 (out_id=0)
[2024/07/04 16:51:58] [ warn] [engine] failed to flush chunk '1-1720111588.707272575.flb', retry in 68 seconds: task_id=450, input=tail.0 > output=es.0 (out_id=0)
Note that TLS works perfectly between Kibana and Elasticsearch, so their configuration seems to be fine.
Now, I have the following config for Fluent-bit for the output plugin:
output-elasticsearch.conf: |
[OUTPUT]
Name es
Match *
Host ${FLUENT_ELASTICSEARCH_HOST}
Port ${FLUENT_ELASTICSEARCH_PORT}
Logstash_Format Off
Replace_Dots On
Retry_Limit False
Suppress_Type_Name On
tls On
tls.verify Off
tls.debug 3
tls.ca_file /fluent-bit/tls/tls.crt
tls.crt_file /fluent-bit/tls/tls.crt
tls.key_file /fluent-bit/tls/tls.key
HTTP_User ${FLUENT_ELASTICSEARCH_USER}
HTTP_Passwd ${FLUENT_ELASTICSEARCH_PASSWORD}
This, in order to mount the certificates, in my daemonSet.yaml:
spec:
containers:
- name: fluent-bit
image: fluent/fluent-bit:3.0.7 # Latest
imagePullPolicy: Always
ports:
- containerPort: 2020
env:
- name: FLUENT_ELASTICSEARCH_HOST
value: "elasticsearch"
- name: FLUENT_ELASTICSEARCH_PORT
value: "9200"
- name: FLUENT_ELASTICSEARCH_USER # Una vez funcione, cargar con secreto
value: "kibana_system" # I am taking advantage of kibana's user
- name: FLUENT_ELASTICSEARCH_PASSWORD
value: "herethepassword"
volumeMounts:
- name: varlog
mountPath: /var/log
- name: varlibdockercontainers
mountPath: /var/lib/docker/containers
readOnly: true
- name: fluent-bit-config
mountPath: /fluent-bit/etc/
- name: tls-certs
mountPath: /fluent-bit/tls
terminationGracePeriodSeconds: 10
volumes:
- name: varlog
hostPath:
path: /var/log
hostPath:
path: /var/lib/docker/containers
configMap:
- name: tls-certs
secret:
secretName: elasticsearch-certs
The elasticsearch-certs is the same that I am currently using with elasticsearch, which is working for the Kibana-elastic communication.
I have found someone with the same issue, not really sure if it is a bug or something is missconfigured: [error] [tls] error: unexpected EOF in versions after 2.0.6 · Issue #8452 · fluent/fluent-bit · GitHub
Also, as said, Kibana works, but is doing the request via URL, not really sure if this means something:
spec:
containers:
- name: kibana
image: docker.elastic.co/kibana/kibana:8.14.1 # Ojo. Same, exactly version than elastic search!!
resources:
limits:
cpu: 1000m
memory: 1Gi
requests:
cpu: 700m
memory: 1Gi
env:
- name: ELASTICSEARCH_URL
value: https://elastic-search.basajaun-cluster:30738
# SERVICE_TOKEN elastic/kibana/kibana-system = AAEAAWVsYXN0aWMva2liYW5hL2tpYmFuYS1zeXN0ZW06VnNGcmF0TlJUY1dGYkRla01OekVvZw
- name: ELASTICSEARCH_USERNAME
- name: ELASTICSEARCH_PASSWORD
value: "thepassword"
- name: ELASTICSEARCH_SSL_VERIFICATIONMODE
value: "none" # Solo en entornos de desarrollo, para producción usar "full"
ports:
- containerPort: 5601
Any help is appreciated.
