Hello, could u please explain what is wrong.
http://pastebin.com/dMZudCsj
my config:
analysis:
analyzer:
default:
type: custom
tokenizer: standard
filter: [mam_ngram, lowercase]
filter:
mam_ngram:
type: nGram
side: front
min_gram: 3
max_gram: 4
token_chars: [letter, digit]
it's a query and ES output.
My mapping has not_analyzed but seems it does not work.
How to check where is issue ?
To unsubscribe from this group and stop receiving emails from it, send an email to elasticsearch+unsubscribe@googlegroups.com .
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/7508f929-1e8b-47fa-b91f-3fd7faf6332e%40googlegroups.com .
For more options, visit https://groups.google.com/groups/opt_out .
Ivan
(Ivan Brusic)
March 4, 2014, 7:29pm
2
Judging by the output, the genre field is analyzed using the default
analyzer. Others can help debug if you provide your mapping. It is best to
use the get mapping API [1] since it shows what you actually have instead
of what you supplied at index creation.
Depending on your use case, you might benefit from using multi-fields. [2]
[1]
Power insights and outcomes with the Elasticsearch Platform and AI. See into your data and find answers that matter with enterprise solutions designed to help you build, observe, and protect. Try Elasticsearch free today.
[2]
Ivan
my config:
analysis:
analyzer:
default:
type: custom
tokenizer: standard
filter:
mam_ngram:
type: nGram
side: front
min_gram: 3
max_gram: 4
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/CALY%3DcQCYZ3WBxpy%3DLPAB3r_bMG7TErq_gA2TAVMjBgSY4ge6Cw%40mail.gmail.com .
Thanks Ivan, I've fixed issue. It was just in wrong mapping.
[1]
Elasticsearch Platform — Find real-time answers at scale | Elastic
[2]
Ivan
On Tue, Mar 4, 2014 at 2:05 AM, Yury Kisliak <fas...@gmail.com <javascript:>
my config:
analysis:
analyzer:
default:
type: custom
tokenizer: standard
filter:
mam_ngram:
type: nGram
side: front
min_gram: 3
max_gram: 4
To view this discussion on the web visit https://groups.google.com/d/msgid/elasticsearch/3227db8d-3af5-417c-811a-664e43ffe944%40googlegroups.com .
