I am running into an issue with filters and facets on not_analyzed (also
tried keyword analyzer, same results) fields. I have tested this with ES
0.19.3, 0.20.4, and 0.90rc1. Basically what happens is that the fields
appear to be analyzed as the facets are the tokenized + downcased values
and filtering on the exact term yields no results. Here is a simple test:
curl -X POST "http://localhost:9200/testing"
curl -X PUT "http://localhost:9200/testing/foo/_mapping" -d
'{"foo":{"properties":{"title":{"type":"string","analyzer":"standard"}},"tags":{"type":"string","index":"not_analyzed"}}}}'
curl -X POST "http://localhost:9200/testing/foo" -d '{"title" : "Foo",
"tags" : ["One"]}'
curl -X POST "http://localhost:9200/testing/foo" -d '{"title" : "Foo Bar",
"tags" : "Two Three"}'
Baz", "tags" : ["One", "Two Three", "Four::Five"]}'
curl -X POST "http://localhost:9200/testing/_refresh"
curl -X GET "http://localhost:9200/testing/foo/_mapping"
Now if I check the facets for a match all query, I get the terms that
appear to be analyzed ("Four::Five" becomes two terms, "four" and "five").
curl -X GET "http://localhost:9200/testing/foo/_search?pretty" -d
'{"facets":{"tagsFacet":{"terms":{"field":"tags","size":10,"all_terms":false}}}}'
"facets": {
"tagsFacet": {
"_type": "terms",
"missing": 0,
"other": 0,
"terms": [{
"count": 2,
"term": "two"
"count": 2,
"term": "three"
"count": 2,
"term": "one"
"count": 1,
"term": "four"
"count": 1,
"term": "five"
"total": 8
This is what I would expect:
"facets": {
"tagsFacet": {
"_type": "terms",
"missing": 0,
"other": 0,
"terms": [{
"count": 2,
"term": "Two Three"
"count": 2,
"term": "One"
"count": 1,
"term": "Four::Five"
"total": 5
Similarly, filtering on an exact term yields no results.
'{"filter":{"term":{"tags":"Two Three"}}}'
"took" : 8,
"timed_out" : false,
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 0,
"max_score" : null,
"hits" : [ ]
I would expect this to return the two documents with exactly that tag. Any
help is greatly appreciated.
Thanks.
