Issues when running 8 clients on single machine
Hi there,
I run into issues while running 8 clients + 1 data node on a single machine
(Macbook Pro 16GB RAM). I get pretty weird JVM errors.
[thread 167427 also had an error]
A fatal error has been detected by the Java Runtime Environment:
SIGSEGV (0xb) at pc=0x000002018b9d8c29, pid=10278, tid=167171
JRE version: 7.0_21-b12
Java VM: Java HotSpot(TM) 64-Bit Server VM (23.21-b01 mixed mode
bsd-amd64 compressed oops)
Problematic frame:
C 0x000002018b9d8c29
Failed to write core dump. [thread 167427 also had an error]
An error report file with more information is saved as:
/Library/WebServer/Documents/CloudPelican/trunk/backend/hs_err_pid10278.log
[error occurred during error repo
[thread 168195 also had an error]
[thread 168451 also had an error]
[thread 168707 also had an error]
[thread 169219 also had an error]
[thread 169731 also had an error]
Is this a known issue?
Best regards,
Robin Verlangen
Data Architect
W http://www.robinverlangen.nl
E robin@us2.nl
http://goo.gl/Lt7BC
What is CloudPelican? http://goo.gl/HkB3D
Disclaimer: The information contained in this message and attachments is
intended solely for the attention and use of the named addressee and may be
confidential. If you are not the intended recipient, you are reminded that
the information remains the property of the sender. You must not use,
disclose, distribute, copy, print or rely on this e-mail. If you have
received this message in error, please contact the sender immediately and
irrevocably delete this message and any copies.
I quickly compiled against Java 6 which doesn't cause any problems. Is a
feasible workaround for now, but maybe this is something useful to debug.
Best regards,
Robin Verlangen
Data Architect
E robin@us2.nl
http://goo.gl/Lt7BC
On Tue, May 21, 2013 at 11:05 PM, Robin Verlangen robin@us2.nl wrote:
Hi there,
machine (Macbook Pro 16GB RAM). I get pretty weird JVM errors.
Problematic frame:
Best regards,
Robin Verlangen
Data Architect
E robin@us2.nl
http://goo.gl/Lt7BC
If you still have the stack traces of the threads in
hs_err_pid10278.log, you should consider to post it for analysis (or to
bother Oracle with it).
Jörg
Am 21.05.13 23:05, schrieb Robin Verlangen:
Hi there,
Problematic frame:
Best regards,
Robin Verlangen
/Data Architect/
E robin@us2.nl mailto:robin@us2.nl
http://goo.gl/Lt7BC
/What is CloudPelican? http://goo.gl/HkB3D/
is intended solely for the attention and use of the named addressee
and may be confidential. If you are not the intended recipient, you
are reminded that the information remains the property of the sender.
You must not use, disclose, distribute, copy, print or rely on this
e-mail. If you have received this message in error, please contact the
sender immediately and irrevocably delete this message and any copies.
