@wkpv68 When do you see that error? Loading discovery in Kibana? Everything is on 6.0?
I'm using official 6.0 for Kibana and elasticsearch
I'm using logstash from 6.0rc2.
I trying to see how can I add (not manually) CouchDB to logstash and than I'll try also the logstash from official 6.0.
Does the problem because I'm using CouchDB? And why CouchDB is not include in official release under logstash?
If you know how to install CouchDB on logstash it will help to test with official logstash 6.0
I'm seeing this error when Loading discovery in kibana
I'm also see this error on logstash consule
Regards and thanks for the help
I was having the exact same problem after upgrading from 5.6.3 -> 6.0
Just trying to delete the .kibana index did not work at first and only resulted in an error.
However, after removing .kibana-6 it seems to have worked, Thank you for the suggestion.
@wkpv68 You should be able to use Logstash 6.0 with the rest of the stack.
What error are you seeing when you try and use this?
I'll try with Logstash 6.0 and also I'll to remove .kibana-6
I can do it only on Sunday.
I'll send the results
It is working
Thanks a lot for the help
@wkpv68 Great, glad to hear!
Sorry for the late response on this. No there is no error. That is why I got some headaches
The terminal commands just runs, with no output what so ever. In ElasticSearch I saw the changes took place.
