Kibana 9.3.0 using <...> parts of log messages as HTML elements on Discover page
Hi, I just upgraded to Kibana 9.3.0 from 9.2.3 and it seems like part of the log message enclosed within <> is removed if it contains alphabet? It doesn’t seem to affect numbers. For example,
2026-02-06 04:41:12,718 INFO some.program.module(128):Search for <John Doe> found <48> items in <0.314> seconds
becomes
2026-02-06 04:41:12,718 INFO some.program.module(128):Search for  found <48> items in <0.314> seconds
in the Discover view page. However, when I click the diagonal arrow on the left side to see the JSON, it contains the full message. Am I doing something wrong or is it a bug?
Hi @aqiank,
Can you please check what value is returned from Elasticsearch by opening Inspect flyout (from the top right corner on Discover page) and navigating to Response tab of it?
Hi @jughosta , the response from inspect contains the correct, unaltered message. Only the main summary view alters the displayed message.
Ah I think I see what the issue is now. After looking at the console, it seems like the <> is being treated as HTML element.
What is the solution type of the current Kibana space? Is it Classic or Observability? Can you please share a redacted screenshot?
It’s Observability. Here’s a screenshot.
Thanks for reporting! We will look into it.
