Kibana issue - Index Patterns: Please specify a default index pattern
Hi Team,
I have setup an ELK Stack and when I am trying to login I am seeing below message -
Used filebeat-* but it is not showing up the save option
Any starting point I need to check.
Kind Regards,
Asif Bhat
cd /etc/logstash/
vim conf.d/filebeat-input.conf
Input configuration: paste the configuration below.
beats {
port => 5443
ssl => true
ssl_certificate => "/etc/pki/tls/certs/logstash-forwarder.crt"
ssl_key => "/etc/pki/tls/private/logstash-forwarder.key"
Save and exit.
Create the syslog-filter.conf file.
vim conf.d/syslog-filter.conf
Paste the configuration below.
if [type] == "syslog" {
grok {
match => { "message" => "%{SYSLOGTIMESTAMP:syslog_timestamp} %{SYSLOGHOST:syslog_hostname} %{DATA:syslog_program}(?:[%{POSINT:syslog_pid}])?: %{GREEDYDATA:syslog_message}" }
add_field => [ "received_at", "%{@timestamp}" ]
add_field => [ "received_from", "%{host}" ]
date {
match => [ "syslog_timestamp", "MMM d HH:mm:ss", "MMM dd HH:mm:ss" ]
We use a filter plugin named 'grok' to parse the syslog files.
Save and exit.
Create the output configuration file 'output-elasticsearch.conf'.
vim conf.d/output-elasticsearch.conf
elasticsearch { hosts => ["localhost:9200"]
hosts => "localhost:9200"
manage_template => false
Save and exit.
Finally add logstash to start at boot time and start the service.
