"event.duration > 10" by itself does not work either.
This is the Request being sent:
"size": 500,
"sort": [
"@timestamp": {
"order": "desc",
"unmapped_type": "boolean"
"version": true,
"fields": [
"field": "*",
"include_unmapped": "true"
"field": "@timestamp",
"format": "strict_date_optional_time"
"field": "event.created",
"field": "event.end",
"field": "event.ingested",
"field": "event.start",
"field": "file.accessed",
"field": "file.created",
"field": "file.ctime",
"field": "file.mtime",
"field": "file.x509.not_after",
"field": "file.x509.not_before",
"field": "kafka.block_timestamp",
"field": "microsoft.defender_atp.lastUpdateTime",
"field": "microsoft.defender_atp.resolvedTime",
"field": "microsoft.m365_defender.alerts.creationTime",
"field": "process.parent.start",
"field": "process.start",
"field": "tls.client.not_after",
"field": "tls.client.not_before",
"field": "tls.client.x509.not_after",
"field": "tls.client.x509.not_before",
"field": "tls.server.not_after",
"field": "tls.server.not_before",
"field": "tls.server.x509.not_after",
"field": "tls.server.x509.not_before",
"field": "x509.not_after",
"field": "x509.not_before",
"field": "zeek.kerberos.valid.from",
"field": "zeek.kerberos.valid.until",
"field": "zeek.ntp.org_time",
"field": "zeek.ntp.rec_time",
"field": "zeek.ntp.ref_time",
"field": "zeek.ntp.xmt_time",
"field": "zeek.ocsp.revoke.time",
"field": "zeek.ocsp.update.next",
"field": "zeek.ocsp.update.this",
"field": "zeek.pe.compile_time",
"field": "zeek.smb_files.times.accessed",
"field": "zeek.smb_files.times.changed",
"field": "zeek.smb_files.times.created",
"field": "zeek.smb_files.times.modified",
"field": "zeek.smtp.date",
"field": "zeek.snmp.up_since",
"field": "zeek.x509.certificate.valid.from",
"field": "zeek.x509.certificate.valid.until",
"aggs": {
"2": {
"date_histogram": {
"fixed_interval": "30m",
"time_zone": "Europe/London",
"min_doc_count": 1
"script_fields": {},
"stored_fields": [
"runtime_mappings": {},
"_source": false,
"bool": {
"must": [],
"filter": [
"bool": {
"filter": [
"bool": {
"should": [
"range": {
"event.duration": {
"gt": "10.0"
"minimum_should_match": 1
"bool": {
"should": [
"range": {
"zeek.dns.rtt": {
"gte": "0.002"
"range": {
"@timestamp": {
"gte": "2021-08-31T08:54:15.634Z",
"lte": "2021-09-01T08:54:15.634Z",
"should": [],
"must_not": []
"highlight": {
"pre_tags": [
"@kibana-highlighted-field@"
"post_tags": [
"@/kibana-highlighted-field@"
"fields": {
"fragment_size": 2147483647
This is the current mapping:
"event": {
"properties": {
"action": {
"type": "keyword",
"ignore_above": 1024
"category": {
"type": "keyword",
"code": {
"type": "keyword",
"created": {
"type": "date"
"dataset": {
"type": "keyword",
"duration": {
"type": "long"
