Limitation for Max number of values for a given field
Is there any limitation for max number of values for a given field?
I am having a use case for a document with 800k distinct values for a given field. each value will be in 10-20 characters and in keyword type. Before I try this in my local cluster, I would like to undersrand if there is any limitation and also best practise for such a case?
Currently, I think this should be still within the max_content_length which is 100MB. and other limit seems does not apply, like max number of nested object and max number of fields.
This sounds unusual. What is the use case? How many such documents are you planning to index? How are you going to query them?
