I can see that the default template has provisions to create raw fields:
{"logstash":{"order":0,"template":"logstash-","settings":{"index":{"refresh_interval":"5s"}},"mappings":{"default":{"dynamic_templates":[{"message_field":{"mapping":{"fielddata":{"format":"disabled"},"index":"analyzed","omit_norms":true,"type":"string"},"match_mapping_type":"string","match":"message"}},{"string_fields":{"mapping":{"fielddata":{"format":"disabled"},"index":"analyzed","omit_norms":true,"type":"string","fields":{"raw":{"ignore_above":256,"index":"not_analyzed","type":"string","doc_values":true}}},"match_mapping_type":"string","match":""}},{"float_fields":{"mapping":{"type":"float","doc_values":true},"match_mapping_type":"float","match":""}},{"double_fields":{"mapping":{"type":"double","doc_values":true},"match_mapping_type":"double","match":""}},{"byte_fields":{"mapping":{"type":"byte","doc_values":true},"match_mapping_type":"byte","match":""}},{"short_fields":{"mapping":{"type":"short","doc_values":true},"match_mapping_type":"short","match":""}},{"integer_fields":{"mapping":{"type":"integer","doc_values":true},"match_mapping_type":"integer","match":""}},{"long_fields":{"mapping":{"type":"long","doc_values":true},"match_mapping_type":"long","match":""}},{"date_fields":{"mapping":{"type":"date","doc_values":true},"match_mapping_type":"date","match":""}},{"geo_point_fields":{"mapping":{"type":"geo_point","doc_values":true},"match_mapping_type":"geo_point","match":""}}],"_all":{"omit_norms":true,"enabled":true},"properties":{"@timestamp":{"type":"date","doc_values":true},"geoip":{"dynamic":true,"type":"object","properties":{"ip":{"type":"ip","doc_values":true},"latitude":{"type":"float","doc_values":true},"location":{"type":"geo_point","doc_values":true},"longitude":{"type":"float","doc_values":true}}},"@version":{"index":"not_analyzed","type":"string","doc_values":true}}}},"aliases":{}}}
Here is the job picking up the default template:
Using mapping template from {:path=>nil, :level=>:info}
Attempting to install template {:manage_template=>{"template"=>"logstash-", "settings"=>{"index.refresh_interval"=>"5s"}, "mappings"=>{"default"=>{"_all"=>{"enabled"=>true, "omit_norms"=>true}, "dynamic_templates"=>[{"message_field"=>{"match"=>"message", "match_mapping_type"=>"string", "mapping"=>{"type"=>"string", "index"=>"analyzed", "omit_norms"=>true, "fielddata"=>{"format"=>"disabled"}}}}, {"string_fields"=>{"match"=>"", "match_mapping_type"=>"string", "mapping"=>{"type"=>"string", "index"=>"analyzed", "omit_norms"=>true, "fielddata"=>{"format"=>"disabled"}, "fields"=>{"raw"=>{"type"=>"string", "index"=>"not_analyzed", "doc_values"=>true, "ignore_above"=>256}}}}}, {"float_fields"=>{"match"=>"", "match_mapping_type"=>"float", "mapping"=>{"type"=>"float", "doc_values"=>true}}}, {"double_fields"=>{"match"=>"", "match_mapping_type"=>"double", "mapping"=>{"type"=>"double", "doc_values"=>true}}}, {"byte_fields"=>{"match"=>"", "match_mapping_type"=>"byte", "mapping"=>{"type"=>"byte", "doc_values"=>true}}}, {"short_fields"=>{"match"=>"", "match_mapping_type"=>"short", "mapping"=>{"type"=>"short", "doc_values"=>true}}}, {"integer_fields"=>{"match"=>"", "match_mapping_type"=>"integer", "mapping"=>{"type"=>"integer", "doc_values"=>true}}}, {"long_fields"=>{"match"=>"", "match_mapping_type"=>"long", "mapping"=>{"type"=>"long", "doc_values"=>true}}}, {"date_fields"=>{"match"=>"", "match_mapping_type"=>"date", "mapping"=>{"type"=>"date", "doc_values"=>true}}}, {"geo_point_fields"=>{"match"=>"", "match_mapping_type"=>"geo_point", "mapping"=>{"type"=>"geo_point", "doc_values"=>true}}}], "properties"=>{"@timestamp"=>{"type"=>"date", "doc_values"=>true}, "@version"=>{"type"=>"string", "index"=>"not_analyzed", "doc_values"=>true}, "geoip"=>{"type"=>"object", "dynamic"=>true, "properties"=>{"ip"=>{"type"=>"ip", "doc_values"=>true}, "location"=>{"type"=>"geo_point", "doc_values"=>true}, "latitude"=>{"type"=>"float", "doc_values"=>true}, "longitude"=>{"type"=>"float", "doc_values"=>true}}}}}}}, :level=>:info}
New Elasticsearch output {:class=>"LogStash::Outputs::ElasticSearch", :hosts=>["127.0.0.1"], :level=>:info}
Why does it not create raw fields? Is there some setting I'm missing?
