Logstash filter jdbc_streaming : JDBC:AdapterNotFound: Could not load jdbc/mssql adapter: adapter class not registered in ADAPTER_MAP>
I'm trying to use logstash filter plugin jdbc_streaming,
my logstash version is 7.13
OS centos 7
openjdk 11.0.11 2021-04-20 LTS
jdbc 6.0 : "/home/jdbc/sqljdbc_6.0/enu/jre7/sqljdbc41.jar"
my logstash config
  generator {
    lines => [
"CBN00000020121",
"CBN00000040121"
    count => 1
filter{
csv{
   columns => ["noinvoice"]
   separator => ","
jdbc_streaming {
    jdbc_driver_library => "/home/jdbc/sqljdbc_6.0/enu/jre7/sqljdbc41.jar"
    jdbc_driver_class => "com.microsoft.sqlserver.jdbc.SQLServerDriver"
    jdbc_connection_string => "jdbc:mssql://someip:1433/mydatabase"
    jdbc_user => "user"
    jdbc_password => "password"
    statement => "select EmailTime from TestInvoice.dbo.storing_ssis WHERE invoiceno= :noinvoice"
    parameters => {"noinvoice" => "noinvoice"}
    target => "EmailTime"
output{
stdout{codec => rubydebug}
When I run by /usr/share/logstash/bin/logstash -f fjdbc.conf
it returns
Using bundled JDK: /usr/share/logstash/jdk
OpenJDK 64-Bit Server VM warning: Option UseConcMarkSweepGC was deprecated in version 9.0 and will likely be removed in a future release.
WARNING: Could not find logstash.yml which is typically located in $LS_HOME/config or /etc/logstash. You can specify the path using --path.settings. Continuing using the defaults
Could not find log4j2 configuration at path /usr/share/logstash/config/log4j2.properties. Using default config which logs errors to the console
[INFO ] 2021-06-10 15:55:36.686 [main] runner - Starting Logstash {"logstash.version"=>"7.13.1", "jruby.version"=>"jruby 9.2.16.0 (2.5.7) 2021-03-03 f82228dc32 OpenJDK 64-Bit Server VM 11.0.11+9 on 11.0.11+9 +indy +jit [linux-x86_64]"}
[WARN ] 2021-06-10 15:55:37.253 [LogStash::Runner] multilocal - Ignoring the 'pipelines.yml' file because modules or command line options are specified
[INFO ] 2021-06-10 15:55:39.668 [Api Webserver] agent - Successfully started Logstash API endpoint {:port=>9600}
[INFO ] 2021-06-10 15:55:41.520 [Converge PipelineAction::Create<main>] Reflections - Reflections took 69 ms to scan 1 urls, producing 24 keys and 48 values
[ERROR] 2021-06-10 15:55:43.988 [[main]-pipeline-manager] javapipeline - Pipeline error {:pipeline_id=>"main", :exception=>#<Sequel::AdapterNotFound: Could not load jdbc/mssql adapter: adapter class not registered in ADAPTER_MAP>, :backtrace=>["/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/database/connecting.rb:97:in `load_adapter'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/adapters/jdbc.rb:380:in `adapter_initialize'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/database/misc.rb:154:in `initialize'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/database/connecting.rb:57:in `connect'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/core.rb:124:in `connect'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-integration-jdbc-5.0.7/lib/logstash/plugin_mixins/jdbc_streaming.rb:62:in `prepare_jdbc_connection'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-integration-jdbc-5.0.7/lib/logstash/filters/jdbc_streaming.rb:122:in `register'", "org/logstash/config/ir/compiler/AbstractFilterDelegatorExt.java:75:in `register'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:228:in `block in register_plugins'", "org/jruby/RubyArray.java:1809:in `each'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:227:in `register_plugins'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:586:in `maybe_setup_out_plugins'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:240:in `start_workers'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:185:in `run'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:137:in `block in start'"], "pipeline.sources"=>["/etc/logstash/fjdbc.conf"], :thread=>"#<Thread:0x67751750 run>"}
[INFO ] 2021-06-10 15:55:43.991 [[main]-pipeline-manager] javapipeline - Pipeline terminated {"pipeline.id"=>"main"}
[ERROR] 2021-06-10 15:55:44.015 [Converge PipelineAction::Create<main>] agent - Failed to execute action {:id=>:main, :action_type=>LogStash::ConvergeResult::FailedAction, :message=>"Could not execute action: PipelineAction::Create<main>, action_result: false", :backtrace=>nil}
[INFO ] 2021-06-10 15:55:44.146 [LogStash::Runner] runner - Logstash shut down.
how i can specify the adapter class?
update
Since I'm using jdk 11, I should've use jdbc 7.2.2. I've specified the path too into /root/jdbc2/sqljdbc_7.2/enu/mssql-jdbc-7.2.2.jre11.jar but it still returning the same error
update2
I've move the jar into /usr/share/logstash/logstash-core/lib/jars/ then change jdbc_driver_library=>""
it still returnin
[ERROR] 2021-06-11 17:07:46.257 [Converge PipelineAction::Create<main>] jdbcstreaming - Invalid setting for jdbc_streaming filter plugin:
    jdbc_streaming {
      # This setting must be a path
      # File does not exist or cannot be opened
      jdbc_driver_library => ""
update 3
I've move the path of the jar, it was /root/jdbc2/sqljdbc_7.2/enu/mssql-jdbc-7.2.2.jre11.jar into /etc/logstash/jar/mssql-jdbc-7.2.2.jre11.jar
when I run again it returning the same error as:
[ERROR] 2021-06-11 17:13:34.597 [[main]-pipeline-manager] javapipeline - Pipeline error {:pipeline_id=>"main", :exception=>#<Sequel::AdapterNotFound: Could not load jdbc/mssql adapter: adapter class not registered in ADAPTER_MAP>, :backtrace=>["/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/database/connecting.rb:97:in `load_adapter'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/adapters/jdbc.rb:380:in `adapter_initialize'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/database/misc.rb:154:in `initialize'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/database/connecting.rb:57:in `connect'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.44.0/lib/sequel/core.rb:124:in `connect'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-integration-jdbc-5.0.7/lib/logstash/plugin_mixins/jdbc_streaming.rb:62:in `prepare_jdbc_connection'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-integration-jdbc-5.0.7/lib/logstash/filters/jdbc_streaming.rb:122:in `register'", "org/logstash/config/ir/compiler/AbstractFilterDelegatorExt.java:75:in `register'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:228:in `block in register_plugins'", "org/jruby/RubyArray.java:1809:in `each'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:227:in `register_plugins'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:586:in `maybe_setup_out_plugins'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:240:in `start_workers'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:185:in `run'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:137:in `block in start'"], "pipeline.sources"=>["/etc/logstash/fjdbc.conf"], :thread=>"#<Thread:0x2a713d1d run>"}
update 4
I freshly redownload jdbc 7.2 as
pwd /home/
mkdir jdbc2
wget https://download.microsoft.com/download/4/D/C/4DCD85FA-0041-4D2E-8DD9-833C1873978C/sqljdbc_7.2.2.0_enu.tar.gz
gzip -d sqljdbc_7.2.2.0_enu.tar.gz
tar -xf sqljdbc_7.2.2.0_enu.tar
use it as final fjdbc.conf
  generator {
    lines => [
"CBN00000020121",
"CBN00000040121"
    count => 1
  generator {
    lines => [
"CBN00000020121",
"CBN00000040121"
    count => 1
filter{
jdbc_streaming {
#    jdbc_driver_library => "/root/jdbc2/sqljdbc_7.2/enu/mssql-jdbc-7.2.2.jre11.jar"
#    jdbc_driver_library => "/etc/logstash/jar/mssql-jdbc-7.2.2.jre11.jar"
    jdbc_driver_library => "/home/jdbc2/sqljdbc_7.2/enu/mssql-jdbc-7.2.2.jre11.jar"
#    jdbc_driver_class => ""
   jdbc_connection_string => "jdbc:mssql://someip:1433/TestInvoice"
#    jdbc_user => "sa"
    jdbc_password => "BIDWT3st!"
output{
This is what I have to connect to microsoft sqlserver
 jdbc {
        jdbc_validate_connection => false
        jdbc_connection_string => "jdbc:sqlserver://server1;databaseName=REPORTING;user=username;password=mypassword;"
        jdbc_user => "username"
        jdbc_password => "mypassword"
        statement => "select * from REPORTING.dbo.v_CONTROLS"
        schedule => "00 06 * * *"
        clean_run=>true
        record_last_run => false
I have copy mssql-jdbc-7.4.1.jre8.jar in to /usr/share/logstash/logstash-core/lib/jars/
Dear Sachin,
thank you so much for your reply. I've done this on update 2. I've copied the jar files into /usr/share/logstash/logstash-core/lib/jars but it still doesn't work.
I will try to do your conf of jdbc_connection_string, but do you have any idea why it <Sequel::AdapterNotFound: Could not load jdbc/mssql adapter: adapter class not registered in ADAPTER_MAP>
Thank you
Dear Sachin,
I've tried on your suggestion.
I'm installing new jdbc as 8.2 it still suit jdk 11.
copy it to /usr/share/logstash/logstash-core/lib/jars/ , removing line jdbc_driver_library, change jdbc_connection_string. It still returning the same error as
[ERROR] 2021-06-14 20:43:54.934 [[main]-pipeline-manager] javapipeline - Pipeline error {:pipeline_id=>"main", :exception=>#<Sequel::AdapterNotFound: Could not load jdbc/mssql adapter: adapter class not registered in ADAPTER_MAP>, :backtrace=>["/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.45.0/lib/sequel/database/connecting.rb:97:in `load_adapter'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.45.0/lib/sequel/adapters/jdbc.rb:380:in `adapter_initialize'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.45.0/lib/sequel/database/misc.rb:154:in `initialize'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.45.0/lib/sequel/database/connecting.rb:57:in `connect'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/sequel-5.45.0/lib/sequel/core.rb:124:in `connect'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-filter-jdbc_streaming-1.0.10/lib/logstash/plugin_mixins/jdbc_streaming.rb:89:in `prepare_jdbc_connection'", "/usr/share/logstash/vendor/bundle/jruby/2.5.0/gems/logstash-filter-jdbc_streaming-1.0.10/lib/logstash/filters/jdbc_streaming.rb:120:in `register'", "org/logstash/config/ir/compiler/AbstractFilterDelegatorExt.java:75:in `register'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:228:in `block in register_plugins'", "org/jruby/RubyArray.java:1809:in `each'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:227:in `register_plugins'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:586:in `maybe_setup_out_plugins'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:240:in `start_workers'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:185:in `run'", "/usr/share/logstash/logstash-core/lib/logstash/java_pipeline.rb:137:in `block in start'"], "pipeline.sources"=>["/etc/logstash/fjdbc.conf"], :thread=>"#<Thread:0x511185bf run>"}
[INFO ] 2021-06-14 20:43:54.937 [[main]-pipeline-manager] javapipeline - Pipeline terminated {"pipeline.id"=>"main"}
[ERROR] 2021-06-14 20:43:54.962 [Converge PipelineAction::Create<main>] agent - Failed to execute action {:id=>:main, :action_type=>LogStash::ConvergeResult::FailedAction, :message=>"Could not execute action: PipelineAction::Create<main>, action_result: false", :backtrace=>nil}
[INFO ] 2021-06-14 20:43:55.078 [LogStash::Runner] runner - Logstash shut down.
this looks like defiantly something to do with driver version mismatch.
you have to do lot of different test as I don't know your configuration. I also spend almost two days testing out different combination and searching on internet and then configuration that I posted work.
this one was the key
Curretnly i have
ls -la /usr/share/logstash/logstash-core/lib/jars/mssql-jdbc-7.4.1.jre8.jar
-rw-r--r-- 1 logstash logstash 1209659 Sep 17 2019 /usr/share/logstash/logstash-core/lib/jars/mssql-jdbc-7.4.1.jre8.jar
Hi sachin, Thank you for your opinion. Yea, It seems so, do you have any reference where abut this plugins jdbc requirements? or it just suit with every jdbc?
when I was testing I started from one point and started writing down which one didn't work and started moving one version up, as it also depend on what version of microsoft sqlserver you have
Hello Sachin,
Yes! I was kind of desperate so I recreate the whole conf file and test each line. Afterall it works and I don't know what makes it so long. Thank you so much for your assistance.
