Match_phrase query does not work when using context suggestions
I am using ES version 5.6.2
We are using an index to store and retrieve our own list of suggestions. We use a match_phrase query to find a specific suggestion and get it's ID. This works fine until we start adding contexts to our suggestion mapping. Somehow, match_phrase does not yield any results in combination with the contexts. I have added the steps to recreate to problem below.
Note: I do not need to search for suggestions, as in, I sent a query for "foot" and it suggests "football" as a result. This is not my problem. My problem is that I want to get the ID for a suggestion that has been indexed.
Create a test index:
   "template":"index_suggest_test*",
   "settings":{
      "number_of_shards":1,
      "number_of_replicas":2
   "mappings":{
      "suggester":{
         "_meta":{
            "version":"1.1.0"
         "properties":{
            "suggest":{
               "type":"completion",
               "analyzer":"whitespace"
            "modified_at":{
               "type":"date"
Insert a suggestion:
   "suggest":{
      "input":[
         "my suggestion"
      "weight":100
   "modified_at":"2018-11-20T15:15:00.000Z"
Search for a specific suggestion: THIS WORKS
        "match_phrase" : { "suggest" : "my suggestion" }
And with contexts it is not working:
Create a test index WITH CONTEXTS:
   "settings":{
   "mappings":{
      "suggester":{
         "_meta":{
            "version":"1.1.0"
         "properties":{
            "suggest":{
               "analyzer":"whitespace",
               "contexts":[
                     "name":"suggest_type",
                     "type":"category"
            "modified_at":{
               "type":"date"
   "suggest":{
      "input":[
         "my suggestion"
      "weight":100,
      "contexts": {
      	"suggest_type" : ["top"]
Search for a specific suggestion: THIS DOES NOT WORK
