Hi!
I recently deployed Elasticsearch with Kibana on Azure Kubernetes environment. After that I deployed Metricbeat and it seems fine, all pods are running without problem.
But I can not see any data flow to Kibana from Metricbeat. When I open the page below, MetricBeat's status seen Offline, after that if I click "Monitor with Metricbeat", I tried lots of different configs(localhost:9200 also) but none one them worked.
"ElasticSearch Home Page" --> "Monitor the stack" --> "Setup Monitoring with Metricbeat"
Metricbeat deployed from here ----> https://github.com/elastic/beats/blob/master/deploy/kubernetes/metricbeat-kubernetes.yaml
Pods and services are like below;
> PS C:\Users\user\Desktop\ES_YAML\2> kubectl get pods --all-namespaces -o wide
> NAMESPACE NAME READY STATUS RESTARTS AGE IP NODE NOMINATED NODE READINESS GATES
> default quickstart-es-default-0 1/1 Running 0 37h 10.240.0.30 aks-aks-35064888-vmss000000 <none> <none>
> default quickstart-kb-b9f8565fc-xfg2n 1/1 Running 0 37h 10.240.0.11 aks-aks-35064888-vmss000000 <none> <none>
> elastic-system elastic-operator-0 1/1 Running 0 37h 10.240.0.44 aks-aks-35064888-vmss000001 <none> <none>
> kube-system azure-cni-networkmonitor-l7xrl 1/1 Running 0 2d11h 10.240.0.4 aks-aks-35064888-vmss000000 <none> <none>
> kube-system azure-cni-networkmonitor-p7g57 1/1 Running 0 2d11h 10.240.0.35 aks-aks-35064888-vmss000001 <none> <none>
> kube-system azure-ip-masq-agent-5kw7q 1/1 Running 0 18d 10.240.0.4 aks-aks-35064888-vmss000000 <none> <none>
> kube-system azure-ip-masq-agent-xr778 1/1 Running 0 18d 10.240.0.35 aks-aks-35064888-vmss000001 <none> <none>
> kube-system coredns-autoscaler-5b6cbd75d7-dk9kd 1/1 Running 0 2d11h 10.240.0.49 aks-aks-35064888-vmss000001 <none> <none>
> kube-system coredns-b94d8b788-8vrks 1/1 Running 0 2d11h 10.240.0.31 aks-aks-35064888-vmss000000 <none> <none>
> kube-system coredns-b94d8b788-m5r8w 1/1 Running 0 2d11h 10.240.0.36 aks-aks-35064888-vmss000001 <none> <none>
> kube-system kube-proxy-cgprj 1/1 Running 0 47d 10.240.0.35 aks-aks-35064888-vmss000001 <none> <none>
> kube-system kube-proxy-j2wn7 1/1 Running 0 47d 10.240.0.4 aks-aks-35064888-vmss000000 <none> <none>
> kube-system metricbeat-49jms 1/1 Running 0 3m23s 10.240.0.4 aks-aks-35064888-vmss000000 <none> <none>
> kube-system metricbeat-l97v9 1/1 Running 0 3m23s 10.240.0.35 aks-aks-35064888-vmss000001 <none> <none>
> kube-system metrics-server-77c8679d7d-tp229 1/1 Running 0 2d11h 10.240.0.12 aks-aks-35064888-vmss000000 <none> <none>
> kube-system tunnelfront-845c87df46-rlbxk 1/1 Running 0 2d11h 10.240.0.19 aks-aks-35064888-vmss000000 <none> <none>
> PS C:\Users\user\Desktop\ES_YAML\2> kubectl get services --all-namespaces
> NAMESPACE NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE
> default elasticsearch-cluster ClusterIP None <none> 9300/TCP 11d
> default elasticsearch-loadbalancer LoadBalancer 10.0.24.232 xx.xx.xxx.150 80:32177/TCP 11d
> default kubernetes ClusterIP 10.0.0.1 <none> 443/TCP 47d
> default quickstart-es-default ClusterIP None <none> 9200/TCP 37h
> default quickstart-es-http ClusterIP 10.0.180.93 <none> 9200/TCP 37h
> default quickstart-es-transport ClusterIP None <none> 9300/TCP 37h
> default quickstart-kb-http ClusterIP 10.0.156.74 <none> 5601/TCP 37h
> elastic-system elastic-webhook-server ClusterIP 10.0.233.68 <none> 443/TCP 37h
> kube-system kube-dns ClusterIP 10.0.0.10 <none> 53/UDP,53/TCP 47d
> kube-system metrics-server ClusterIP 10.0.183.253 <none> 443/TCP 47d
How can I solve this issue?
Thanks!
