Metricbeat data flow problem
I recently deployed Elasticsearch with Kibana on Azure Kubernetes environment. My env's is like below;
>     PS C:\Users\user\Desktop\ES_YAML\2> kubectl get pods --all-namespaces -o wide
>     NAMESPACE        NAME                                  READY   STATUS    RESTARTS   AGE     IP            NODE                          NOMINATED NODE   READINESS GATES
>     default          quickstart-es-default-0               1/1     Running   0          37h     10.240.0.30   aks-aks-35064888-vmss000000   <none>           <none>
>     default          quickstart-kb-b9f8565fc-xfg2n         1/1     Running   0          37h     10.240.0.11   aks-aks-35064888-vmss000000   <none>           <none>
>     elastic-system   elastic-operator-0                    1/1     Running   0          37h     10.240.0.44   aks-aks-35064888-vmss000001   <none>           <none>
>     kube-system      azure-cni-networkmonitor-l7xrl        1/1     Running   0          2d11h   10.240.0.4    aks-aks-35064888-vmss000000   <none>           <none>
>     kube-system      azure-cni-networkmonitor-p7g57        1/1     Running   0          2d11h   10.240.0.35   aks-aks-35064888-vmss000001   <none>           <none>
>     kube-system      azure-ip-masq-agent-5kw7q             1/1     Running   0          18d     10.240.0.4    aks-aks-35064888-vmss000000   <none>           <none>
>     kube-system      azure-ip-masq-agent-xr778             1/1     Running   0          18d     10.240.0.35   aks-aks-35064888-vmss000001   <none>           <none>
>     kube-system      coredns-autoscaler-5b6cbd75d7-dk9kd   1/1     Running   0          2d11h   10.240.0.49   aks-aks-35064888-vmss000001   <none>           <none>
>     kube-system      coredns-b94d8b788-8vrks               1/1     Running   0          2d11h   10.240.0.31   aks-aks-35064888-vmss000000   <none>           <none>
>     kube-system      coredns-b94d8b788-m5r8w               1/1     Running   0          2d11h   10.240.0.36   aks-aks-35064888-vmss000001   <none>           <none>
>     kube-system      kube-proxy-cgprj                      1/1     Running   0          47d     10.240.0.35   aks-aks-35064888-vmss000001   <none>           <none>
>     kube-system      kube-proxy-j2wn7                      1/1     Running   0          47d     10.240.0.4    aks-aks-35064888-vmss000000   <none>           <none>
>     kube-system      metricbeat-49jms                      1/1     Running   0          3m23s   10.240.0.4    aks-aks-35064888-vmss000000   <none>           <none>
>     kube-system      metricbeat-l97v9                      1/1     Running   0          3m23s   10.240.0.35   aks-aks-35064888-vmss000001   <none>           <none>
>     kube-system      metrics-server-77c8679d7d-tp229       1/1     Running   0          2d11h   10.240.0.12   aks-aks-35064888-vmss000000   <none>           <none>
>     kube-system      tunnelfront-845c87df46-rlbxk          1/1     Running   0          2d11h   10.240.0.19   aks-aks-35064888-vmss000000   <none>           <none>
>     PS C:\Users\user\Desktop\ES_YAML\2> kubectl get services --all-namespaces
>     NAMESPACE        NAME                         TYPE           CLUSTER-IP     EXTERNAL-IP     PORT(S)         AGE
>     default          elasticsearch-cluster        ClusterIP      None           <none>          9300/TCP        11d
>     default          elasticsearch-loadbalancer   LoadBalancer   10.0.24.232    xx.xx.xxx.150   80:32177/TCP    11d
>     default          kubernetes                   ClusterIP      10.0.0.1       <none>          443/TCP         47d
>     default          quickstart-es-default        ClusterIP      None           <none>          9200/TCP        37h
>     default          quickstart-es-http           ClusterIP      10.0.180.93    <none>          9200/TCP        37h
>     default          quickstart-es-transport      ClusterIP      None           <none>          9300/TCP        37h
>     default          quickstart-kb-http           ClusterIP      10.0.156.74    <none>          5601/TCP        37h
>     elastic-system   elastic-webhook-server       ClusterIP      10.0.233.68    <none>          443/TCP         37h
>     kube-system      kube-dns                     ClusterIP      10.0.0.10      <none>          53/UDP,53/TCP   47d
>     kube-system      metrics-server               ClusterIP      10.0.183.253   <none>          443/TCP         47d
Regarding to my env (pods and services) above, what should I put for "HOST" and "PORT" variables on metricbeat.yaml?
Capture
I will admit upfront I am not a kubernetes expert at all, but I would try the loadbalancer IP and port.
