Missing create/add index button in Kibana
I have newly installed Kibana with elastisearch but to connect with Kibana and elasticsearch I am supposed to create a index pattern but I don;t see any CREATE/ADD button under index pattern.
Kibana version- 6.1.3
Elasticsearch-6.1.1
I am doing POC for my cassandra log analysis.. I am new to ELK
Can anyone help me? I am attaching image below.
Can you check that you have data in Elasticsearch via _cat/indices?
Here is the output.
elk@localhost ~]$ curl 'localhost:9200/_cat/indices?v'
health status index uuid pri rep docs.count docs.deleted store.size pri.store.size
yellow open customer ddE-cIiqRXqVHRpf1StoUw 5 1 0 0 1.1kb 1.1kb
Chandra
It's working now.
After adding some data into elasticksearch I am able to create index pattern on Kibana.
Chandra
