Multi_match:best_fields with complex queries no dis_max
Is there any way to use the multi_match interface using these more complex matchs?
Obs: I believe that multi_match: best_fields works as if it were an alias pro dis_max in this situation mentioned
I am trying to use multi_match to execute some queries, but as I read in the documentation, I noticed that within the multi_match context I can not make explicit the whole complex structure of each field, for example:
     "multi_match": {
        "query":    "quick brown fox",
         "fields": [ "title", "body" ],
         "type":     "best_fields"      # default
This structure above represents a simple multi_match where it was not parameterized anything besides the fields used in the match and the value of the query, if I were for example want to put zero_terms_query already could not because multi_match does not support this parameter, having as a following way:
    "dis_max": {
        "queries": [
            { "match": { "title": {
                             "query" : "quick brown fox",
                             "zero_terms_query" : 'all'
            { "match": { "body":  "quick brown fox" }}
I was able to do it by applying some parameters inside the own multi-match, as below:
      'must' => [
                    'multi_match' => [
                        'query' => '{{query}}',
                        'zero_terms_query' => 'all',
                        'operator' => 'and',
                        'fields' => []
